10-18-2011 11:48 AM - edited 03-21-2019 04:49 AM
I have the SPA 8800 connect to my UC320 the FXO ports work fine, but I can't get dial tone on the FXS port. The FXS port on the UC320 works fine and the FXS ports in the UC320 configuration are enabled, but I can't find any additional setting that give me a hint on what I'm doing wrong.
Any help would very much be appreciated. Thanks
Solved! Go to Solution.
10-18-2011 01:31 PM
Hi Michael,
In order to get dial tone, you must assign the SPA8800 FXS to a user. You can assign them by location -i.e. Lunch Room.
Let us know if this solved issue for you.
Cheers,
Julio
10-18-2011 01:31 PM
Hi Michael,
Cheers,
Julio
10-20-2011 10:07 AM
Thank you. I knew I was missing something simple.
