Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
1272
Beginner
SPA 9000 + SPA400 - AA - 'no match' problem
Hi guys,
below is the AA script from my SPA900, I´m using extensions like 101, 102, 103 and ... I was testing the AA and able to hear the prompt1 asking about extension number and then if I press another number like 200 I heard the prompt3 saying about the call is in transfer. Transfer???? To where? I dont have extensions starting by '2xx'!!!!
>>> pressing '*' o r '#' it the only way to listen the prompt3!
Why??? What I did wrong? Or it´s correct?
AA Script
<aa><form id="dir" type="menu"><audio src="prompt1" bargein="T"/><noinput timeout="10" repeat="T"/><nomatch repeat="F"><audio src="prompt3" bargein="T"/></nomatch><dialplan src="dp1"/><match><default><audio src="prompt2"/><xfer name="ext" target="$input"/></default></match></form></aa>
Everyone's tags (5)
1 ACCEPTED SOLUTION
Highlighted
Re: SPA 9000 + SPA400 - AA - 'no match' problem
Hi Renato;
The dial plan you have below basically allows to dial anything which is larger than 2 digits, no matter what (xxx.). If you don’t want the autoattendant to process anything different that the options and the extension numbers, please enter the following:
(10x|x)
Alberto
6 REPLIES 6
Highlighted
Can you please provide the AA dial plan (it is next the AA script)?
Alberto
Highlighted
Beginner
Alberto,
below is the information.
AA Dial Plan 1: (10x|xxx.)
AA Dial Plan 2: (<:10>x|xxx.)
tks,
Renato Pereira
Highlighted
Hi Renato;
(10x|x)
Alberto
Highlighted
Beginner
Alberto,
I tryed exactly as you wrote but still dont work... What we can do?
tks,
Renato Pereira
Highlighted
Beginner
Hi Alberto,
I fixed using the following 'AA Dial Plan1':
'(1|1xx)'
tks
Renato Pereira
Highlighted
Hi Renato;
Good! Actually I made a basic mistake, you need to put the more specific rules at the beginning (e.g. shorter matches) then larger or more general. You did it great.
Regards;
Alberto
