spa301 speakerphone
johnhorvath1
According to the product datasheet and manual, there is no speakerphone for the SPA301. However, in the web config utility under the User tab in the Audio section there is a Speakerphone Enable option. Also, while I was once playing around with the IVR I inadvertently hit several keys at once and the IVR then came out of the speaker and not the handset. I tried pressing different buttons to have it go back to normal but the IVR kept going even with the handset on hook. I was only able to revert to the previous state by powering the unit off and then on again. Unfortunately I have been unable to repeat this procedure because I can't remember which buttons I had accidentally pushed in combination.
This makes me think that perhaps it is possible to use a speakerphone function on the SPA301. My question is that is it absolutely true that a speakerphone option can't be used with the SPA301 and, if not, then why is there an option for it in the web config utility?
Thanks in advance,
John
0 Replies 0
