Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1412
peterbata
Beginner
SPA303 Firmware Upgrade Fails
Hello all. First time post.
A little bit about my environment.
Windows 7 Pro home use. No antivirus. Very simple home setup. Launching the update from my laptop. Phone is plugged into a swith on the same subnet. Phone IP = 192.168.0.223. Laptop IP 192.168.0.100. I am able to browse phone settings via browser at http://192.168.0.223
I am attempting to apply Firmware update v7.6.1 to my SPA303. It is currently showing v7.5.2 as the current version. I have downloaded the appropriate files the Cisco firmware download section.
I execute spa50x-30x-7-4-6.exe / the upgrade process begins but always results in this:
After scouring the internet for a while I came across this, but it has not helped either
The solution, through trial and error, was to use a URL pointing to a web server that had the .bin file on it.  In my case, I had a local web server that I copied the file to and then used the URL:
http://MySPAAddr/upgrade?http://mywebserver/theSPAupdatefile.bin
Your time and assistance would be greatly apppreciated. Thank you all in advance
3 REPLIES 3
Jaime Valencia
Hall of Fame Cisco Employee
SPA phones are covered in the SMB community, might want to move your thread over there.
java
if this helps, please rate
Thank you Jaime, I will do that.
Dan Lukes
Advocate
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
