05-03-2016 12:25 PM - edited 03-21-2019 08:55 AM
Hello all. First time post.
A little bit about my environment.
Windows 7 Pro home use. No antivirus. Very simple home setup. Launching the update from my laptop. Phone is plugged into a swith on the same subnet. Phone IP = 192.168.0.223. Laptop IP 192.168.0.100. I am able to browse phone settings via browser at http://192.168.0.223
I am attempting to apply Firmware update v7.6.1 to my SPA303. It is currently showing v7.5.2 as the current version. I have downloaded the appropriate files the Cisco firmware download section.
I execute spa50x-30x-7-4-6.exe / the upgrade process begins but always results in this:
After scouring the internet for a while I came across this, but it has not helped either
The solution, through trial and error, was to use a URL pointing to a web server that had the .bin file on it. In my case, I had a local web server that I copied the file to and then used the URL:
http://MySPAAddr/upgrade?http://mywebserver/theSPAupdatefile.bin
Your time and assistance would be greatly apppreciated. Thank you all in advance
05-03-2016 01:22 PM
SPA phones are covered in the SMB community, might want to move your thread over there.
05-03-2016 08:23 PM
Thank you Jaime, I will do that.
02-18-2017 11:07 AM
Duplicate of SPA303 Firmware Upgrade Error
