SPA303 forever reboots
yuretz1488
HI!
My SPA303 stuck into forever rebooting:
1) It's starts, light are flashing
2) Cisco Logo
3) Initializing Network
4) Checking DNS
5) Reboot and all the same from №1 position.
So i'm not able restore factory settings from menu just beacuse i have no time to do that.
I think there must way to hard reset phone to default settings without menu system.
Please help me.
nseto
Level 6
Level 6
It sounds like the network cable is still connnected, can you disconnect that and have just the power connected?  Then see if you can get into the menu?
I've got same result with plugged and unplugged network cable.
Still reboots.
arcanosintercom
When you have the Initializing network screen, you should have time to access the phone menu (at least if you use dhcp).
Do you have a BMP picture loaded in the screen?
If so, it could be our problem... https://supportforums.cisco.com/message/3786793#3786793
Let me know, because I'm going crazy about this!
Alberto
i'm trying to access - but initizlizing network takes not more than 1 second.i've tryed to push menu button - that doesn't help
is thete any ways to reset phone without menu?
