1957
Highlighted
Beginner
SPA3102 saying "Password Invalid" when making VOIP calls
I had to move a re set up the SPA3102 VOIP gateway router.
Now when I try to make an outgoing call I get the message "That password is  not valid".
I do not believe that this refers to my VOIP provider account as when I use  the same password in a modem it works.
Any ideas. As it stands I can't make any VOIP calls out.
5 REPLIES 5
Highlighted
Hi Lance
Inside spa PSTN tab you have options to request password to access even voip or pstn lines.
Please take a look there and if possible copy the config here then we can check it.... Be aware to remove your sensitive information like usernames and passwords
Tks
Rgrds
Highlighted
Thanks for the quick reply though I'm not really sure what data fields you require.
Do you want me to go to
http://192.168.1.1/admin/voice/advanced
then to the "PSTN Line" tab?
Once there if that is the tab to be in, I'm not sure which fields you want to look at. There are too many to copy into here and I'm not sure what you mean by "you have options to request password to access even voip or pstn lines".
Thanks again,
Lance
Highlighted
Right Lance,
Try to save this page as MHT on your browser or take screen shots.
Regards.
Andrey Cassemiro.
Highlighted
Hi Andrew,
Thanks for hanging in there.
Below is a screen shot.
Lance
Highlighted
Hi Lance,
Contact me at acassemi at cisco dot com then we can speed up the solution.
The configuration to PSTN line looks fine, with no PIN required.
I just want to get logs with you and analyze the Line 1 config.
Regards.
Andrey Cassemiro.
