11-18-2013 06:28 AM - edited 03-21-2019 07:55 AM
Would you help me with this problem
I have an installation with a SPA400+SPA900 and phones 3x SPA942. Country is Czech Republic.
Incoming calls shows "Anonymous caller" instead of showing the caller id. I follow some instructions, I have seen, in a documentation that talks about that, but still does not work.
I have set up the following configuration on the SPA400 for Czech Republic.
Receive Gain:0
Impedance: 270+(750||150nF)
Tip/Ring Voltage: 3.5 V
Operational Loop Current Min: 10 mA
On-hook Speed: 3 ms
DC Current Limiting: Enable
Caller ID Method 'European (FSK)'
Do you have any idea what it could be changed in the config?
Thank you for your support
Best Regards
Pavel Srajer
02-17-2014 02:00 AM
Hi Pavel,
I had similar problems here in Australia with the default Australia setting for caller ID not working.
I set it to the USA standard (which Australia also uses) and it is OK.
Not sure if this will help with using it in CZ but try different standards and see how you go, best of luck.
02-19-2014 12:27 PM
have you tried plugging an analog phone into the wall jack to see if your provider is sending Callerid?
have you talked to your provider to find out what settings they are sending?
If the device is under warranty or contract, you can call into the Cisco small business help desk and open a case.
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Dan
