11-19-2010 05:29 AM - edited 03-21-2019 03:17 AM
We have a SPA9000 + SPA400
The problem is when the SPA400 voice mail system is updated to PT PCM files, the call is transfered to VM, we get a PT voice prompt (translated here) "Extension XXX is not avaliable" and then drops.
If the US PCM or US GSM files are in place, than the SPA400 VM takes the call to mailbox ok
Is there any other set of PT PCM files that we can use ?
Solved! Go to Solution.
11-26-2010 04:39 AM
Hi Helder;
Thanks. Can you please mark the question as answered? This helps other people finding the answer to a similar question.
Alberto
11-22-2010 08:35 AM
Dear Sir;
What language you have configured on the SPA400 GUI, portuguese or English? Please use english and let me know if this is still broken. We saw some issues with the languages pack (with other languages).
Can you please check if the following prompts are on the portuguese pack?
beep
vm-intro
vm-first
digits/1
Regards;
Alberto
11-24-2010 09:14 AM
The SPA400 GUI is English from the very begining (i never did change it)
As with the files in the PT package:
beep - nonexistent
vm-intro - nonexistent
vm-first - nonexistent
digits/1 - file PT ok
Noticed many other files are missing from the PT package when compared to the EN package but these probably dont apply here.
Also did some tests, by merging PT and US packages, and now VM does not drop anymore but some sentences are a mix of PT and US (i think it means that in fact some files are missing from the PT package).
11-25-2010 07:44 AM
Dear Helder;
Please check https://supportforums.cisco.com/docs/DOC-9871
We have updated the prompts (there were some missing-misslabeled). Please load and let us know the results.
Regards, and thanks for highlighting the issue
Alberto
11-26-2010 02:53 AM
Problem solved
All prompts now "speek" PT
Helder
11-26-2010 04:39 AM
Hi Helder;
Alberto
