SPA500s BLF field problem with speed dial.
viewtekmsd
Hi all and thanks for reading,
I am assigning speed dials to SPA500s attendant console. I am using a script like the one below.
fnc=sd;JoeSmith@10.1.1.10;ext=0043xxxxxxx@10.1.1.10;nme=JoeSmith
As you can see the only function programmed is sd but the light stays green permanently. The script works but I need to get rid of the lights as it is driving the client mad. Source code of GUI is attached if needed.
Thanks Michael
0 Replies 0
