Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
7190
Highlighted
Beginner
SPA500s BLFs not working
Cannot get the SPA500S to show BLFs once we upgraded the firmware to 7.4.8 from 7.4.3. Has their been a change in how we need write the config?
Current config template that previously worked in 7.4.3:
  <!-- Busy Lamp Field Configuration -->
  <Unit_1_Enable ua="na">Yes</Unit_1_Enable>
  <Unit_2_Enable ua="na">No</Unit_2_Enable>
  <Server_Type ua="na">Broadsoft</Server_Type>
  <Test_Mode_Enable ua="na">No</Test_Mode_Enable>
  <Attendant_Console_Call_Pickup_Code group="Attendant_Console/General">*98</Attendant_Console_Call_Pickup_Code>
  <BLF_List_URI group="Attendant_Console/General">%BWBLF-USER-1%@172.27.0.1</BLF_List_URI>
  <!-- Unit 1 -->
  <Unit_1_Key_1 ua="na">fnc=sd+blf+cp;sub=%BWBLF-USER-1%@172.27.0.1; usr=USERID@HOST</Unit_1_Key_1>
  <Unit_1_Key_2 ua="na"></Unit_1_Key_2>
  <Unit_1_Key_3 ua="na"></Unit_1_Key_3>
  <Unit_1_Key_4 ua="na"></Unit_1_Key_4>
  <Unit_1_Key_5 ua="na"></Unit_1_Key_5>
  <Unit_1_Key_6 ua="na"></Unit_1_Key_6>
  <Unit_1_Key_7 ua="na"></Unit_1_Key_7>
  <Unit_1_Key_8 ua="na"></Unit_1_Key_8>
  <Unit_1_Key_9 ua="na"></Unit_1_Key_9>
  <Unit_1_Key_10 ua="na"></Unit_1_Key_10>
  <Unit_1_Key_11 ua="na"></Unit_1_Key_11>
  <Unit_1_Key_12 ua="na"></Unit_1_Key_12>
  <Unit_1_Key_13 ua="na"></Unit_1_Key_13>
  <Unit_1_Key_14 ua="na"></Unit_1_Key_14>
  <Unit_1_Key_15 ua="na"></Unit_1_Key_15>
  <Unit_1_Key_16 ua="na"></Unit_1_Key_16>
  <Unit_1_Key_17 ua="na"></Unit_1_Key_17>
  <Unit_1_Key_18 ua="na"></Unit_1_Key_18>
  <Unit_1_Key_19 ua="na"></Unit_1_Key_19>
  <Unit_1_Key_20 ua="na"></Unit_1_Key_20>
  <Unit_1_Key_21 ua="na"></Unit_1_Key_21>
  <Unit_1_Key_22 ua="na"></Unit_1_Key_22>
  <Unit_1_Key_23 ua="na"></Unit_1_Key_23>
  <Unit_1_Key_24 ua="na"></Unit_1_Key_24>
  <Unit_1_Key_25 ua="na"></Unit_1_Key_25>
  <Unit_1_Key_26 ua="na"></Unit_1_Key_26>
  <Unit_1_Key_27 ua="na"></Unit_1_Key_27>
  <Unit_1_Key_28 ua="na"></Unit_1_Key_28>
  <Unit_1_Key_29 ua="na"></Unit_1_Key_29>
  <Unit_1_Key_30 ua="na"></Unit_1_Key_30>
  <Unit_1_Key_31 ua="na"></Unit_1_Key_31>
  <Unit_1_Key_32 ua="na"></Unit_1_Key_32>
Everyone's tags (4)
1 REPLY 1
Participant
yes, the profile format is different for each version of firmware.
download the profile compiler here
http://www.cisco.com/cisco/software/type.html?mdfid=282724650&flowid=5300
or
http://www.cisco.com/cisco/software/release.html?mdfid=282724650&flowid=5300&softwareid=282562500&release=7.4.8&relind=AVAILABLE&rellifecycle=&reltype=latest
to  create a new template for 7.4.8 (in windows)
unzip the files
go to the folder
--sample-profile output_filename
It's probably a good idea to use that template for all configuration / provisioning of the phones with that version of firmware.  Some features may have been added and some may have changed.
DLM...
