08-14-2019 04:52 PM
I have several SPA501G phones which i'm trying to set up speed dials on.
Here are the settings:
Assume the IP/network config and SIP/proxy config is OK. This has been tested.
The PBX is also working as other types of phones work on it, and I can see that this phone registers to it.
Ext 1 dial plan: ([23456789]xxxxxxx|0[123456789]xxx|18xx|1[12345679]x|00xx.)
Probably unrelated, I have Ext 2-8 diabled ("Line enable: no"). I only use Ext 1.
Line key 1 is an 3-digit number.
Line key 2 is an 8-digit number.
Now before I set the line key settings, i was able to call with the phone when punching in the number. After i set the line key options however this also stopped working, in addition to the line keys not working.
Does anybody have any experience setting up line key speed dials on these phones, and would be so kind to give me some advice?
Solved! Go to Solution.
08-14-2019 05:01 PM
OK, but where you have a Line Key associated with Ext 1 ? It seems you have no one - it causes you are unable to dial (either by dialing number manually or via SD).
08-14-2019 05:01 PM
08-15-2019 05:01 PM
Thank you for your reply, Dan.
I do not have a "Line Key" on the "Phone" tab associated with Ext1.
I will associate one of the unused line keys (which i don't have speed dial on) with Ext1 "Private" and test to see if it works and report back.
08-21-2019 05:12 PM
Your suggestion solved my problem. Thank you for your help, Dan.
08-24-2019 09:08 AM
Glad to hear.
Cheers, Dan
