SPA504G Missed Calls ?
briangroper
Hi forum
It seems I'm getting no missed calls logged into the Missed Calls register.
Is there some config setting needed to turn on this feature ?
Simply, if an incoming caller hangs up without leaving voicemail, I'm getting no record of this event.
TIA's for any tips or clues.
briangroper
Found solution in web interface.
Yes, there is a feature to turn on.
See User, Supplementary Services
Log Missed Calls for EXT 1-4 Yes/No
How do I mark this question as "answered" ?
It's unfortunate feature of this forum. You can't mark your own comment as answer. You need to mark someone else's comment as answer even it contain no answer at all.
By the way, even in the case you turn on "Log Missed Calls" on, some calls may not be recorded. It apply to calls cancelled by PBX with "answered elsewhere" code (e.g. mostly group calls answered on other phone).
