SPA504G PC Port Disabling
BernardMagic
I was hoping to gain some assistance in editing the SPA504G's startup configuration file to disable the PC Port.
I've edited a good amount of other settings in the XML configuration, however, I'm not sure what XML command I'd need to send in order to disable the PC Port.
Any assistance in discovering the code required to do this would be greatly appreciated.
Thank you,
Bernie
Patrick Born
Hi Bernie,
There is no way to disable the phone's PC port. You could move it to an unused VLAN if you like:
I've attached the configuration template from a SPA50x phone so you can see the configurable parameters.
I'm curious, why are you wanting to disable the PC port?
Patrick
******** start of configuration template *********
http://www.sipura.net/xsd/SPA50x-30x-SIP" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.sipura.net/xsd/SPA50x-30x-SIP http://www.sipura.net/xsd/SPA50x-30x-SIP/SPA50x-30x-SIP-7-4-8a.xsd">
  Yes
  80
  Yes
  SIP
  Yes
  No
  No
  Normal
  DHCP
  Manual
  Parallel
  No
  No
  No
  Yes
  Yes
  No Limit
  No
  Yes
  Yes
  3600
  14400
  Yes
  Yes
  Yes
  /spa$PSN.cfg
  66,160,159,150
  https
  $PN $MAC -- Requesting resync $SCHEME://$SERVIP:$PORT$PATH
  $PN $MAC -- Successful resync $SCHEME://$SERVIP:$PORT$PATH
  $PN $MAC -- Resync failed: $ERR
  Yes
  Yes
  3600
  $PN $MAC -- Requesting upgrade $SCHEME://$SERVIP:$PORT$PATH
  $PN $MAC -- Successful upgrade $SCHEME://$SERVIP:$PORT$PATH -- $ERR
  $PN $MAC -- Upgrade failed: $ERR
  70
  $VERSION
  $VERSION
  application/dtmf-relay
  application/hook-flash
  No
  No
  No
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  5060
  5080
  No
  PAID-RPID-FROM
  x-sipura
  No
  No
  .5
  16
  16
  16
  16
  240
  30
  30
  1200
  16538
  0.030
  No
  No
  No
  101
  98
  97
  99
  112
  113
  G711u
  telephone-event
  PCMU
  PCMA
  G726-16
  G726-24
  G726-32
  G726-40
  G729a
  G729ab
  G723
  G722
  L16
  encaprtp
  No
  No
  No
  No
  No
  No
  No
  No
  15
  No
  224.168.168.168:6061
  Yes
  none
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5060
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5061
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5062
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5063
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5064
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5065
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5066
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5067
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5068
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5069
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5070
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  Yes
  private
  3600
  No
  No
  No
  $NOTIFY
  $PROXY
  0x68
  0xb8
  6
  high
  up and down
  UDP
  5071
  No
  Yes
  No
  No
  none
  No
  No
  Yes
  Yes
  none
  No
  No
  No
  No
  No
  Yes
  No
  Yes
  Yes
  No
  3600
  No
  No
  No
  3600
  Normal
  No
  G711u
  No
  Unspecified
  Unspecified
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Auto
  No
  Default
  Yes
  20
  Yes
  No
  No
  No
  No
  No
  Yes
  Speaker
  No
  12hr
  month/day
  Yes
  Yes
  automatic
  source
  media
  Yes
  No
  No
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  8
  8
  Default
  8
  10 s
  None
  Auto
  No
  300
  Background Picture
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  $USER
  private
  Vertical First
  No
  No
  Per Line
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  Yes
  No
  Yes
  No
  n=Classic-1;w=3;c=1
  n=Classic-2;w=3;c=2
  n=Classic-3;w=3;c=3
  n=Classic-4;w=3;c=4
  n=Simple-1;w=2;c=1
  n=Simple-2;w=2;c=2
  n=Simple-3;w=2;c=3
  n=Simple-4;w=2;c=4
  n=Simple-5;w=2;c=5
  n=Office;w=4;c=1
  Yes
  pggrp=224.168.168.168:34560;name=All;num=800;listen=yes;
  No
  Enterprise
  Disabled
  No
  None
  No
  No
  em_login|1;acd_login|1;acd_logout|1;avail|3;unavail|3;redial|5;dir|6;cfwd|7;dnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout
  lcr|1;miss|4
  redial|1;dir|2;cfwd|3;dnd|4;lcr|5;unpark|6;pickup|7;gpickup|8;starcode|11;alpha|12
  dial|1;delchar|2;clear|3;cancel|4;left|5;right|6;starcode|7;alpha|8;dir
  endcall|2
  hold|1;endcall|2;conf|3;xfer|4;toggle;bxfer;confLx;xferLx;park;phold;flash;
  hold|1;endcall|2;xfer|4;toggle;
  hold|1;endcall|2;conf|3;toggle;
  hold|1;endcall|2;join|4
  endcall|2;
  resume|1;endcall|2;newcall|3;redial;dir;cfwd;dnd
  answer|1;ignore|2;toggle|4
  newcall|1;barge|2;cfwd|3;dnd|4
  resume|1;barge|2;cfwd|3;dnd|4
  350@-19,440@-19;10(*/0/1+2)
  420@-16;10(*/0/1)
  520@-19,620@-19;10(*/0/1+2)
  480@-19,620@-19;10(.5/.5/1+2)
  480@-19,620@-19;10(.25/.25/1+2)
  480@-10,620@0;10(.125/.125/1+2)
  440@-19,480@-19;*(2/4/1+2)
  440@-10;30(.3/9.7/1)
  600@-16;1(.25/.25/1)
  985@-16,1428@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)
  914@-16,1371@-16,1777@-16;20(.274/0/1,.274/0/2,.380/0/3,0/4/0)
  914@-16,1371@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)
  985@-16,1371@-16,1777@-16;20(.380/0/1,.274/0/2,.380/0/3,0/4/0)
  350@-19,440@-19;2(.1/.1/1+2);10(*/0/1+2)
  350@-19,440@-19;2(.2/.2/1+2);10(*/0/1+2)
  600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)
  350@-19;20(.1/.1/1,.1/9.7/1)
  397@-19,507@-19;15(0/2/0,.2/.1/1,.1/2.1/2)
  600@-16;.3(.05/0.05/1)
  600@-19;.2(.05/0.05/1)
  60(2/4)
  60(.3/.2,1/.2,.3/4)
  60(.8/.4,.8/4)
  60(.4/.2,.3/.2,.8/4)
  60(.2/.2,.2/.2,.2/.2,1/4)
  60(.2/.4,.2/.4,.2/4)
  60(4.5/4)
  60(0.25/9.75)
  60(.4/.2,.4/2)
  255
  1800
  30
  .5
  *69
  *98
  *66
  *86
  *72
  *73
  *90
  *91
  *92
  *93
  *56
  *57
  *71
  *70
  *67
  *68
  *81
  *82
  *77
  *87
  *78
  *79
  *16
  *17
  *18
  *19
  *96
  *38
  *36
  *39
  *37
  *03
  *017110
  *027110
  *017111
  *027111
  *01723
  *02723
  *01722
  *02722
  *01016
  *02016
  *0172616
  *0272616
  *0172624
  *0272624
  *0172632
  *0272632
  *0172640
  *0272640
  *01729
  *02729
  GMT-08:00
  Yes
  Yes
  -16
  .1
  12dB
  ISO-8859-1
  1800
  30
  Yes
  Yes
  Broadsoft
  No
  *98
  No
******** end of configuration template *********
Hi Patrick,
Thank you very much for your prompt response! We're interested in disabling the PC Port because we have a dedicated connection for our phone system and a separate dedicated line for all computers. Essentially we're trying to prevent users from connecting their computers to the PC Port on the phone system and potentially bogging down our VoIP setup.
Unfortunately moving the PC Port to an unused VLAN doesn't prevent the user from accessing the internet (at least to my knowledge, [although I thought it would]). But thank you very much for your assistance. I greatly appreciate it.
-Bernie
