02-21-2012 02:54 PM - edited 03-21-2019 05:23 AM
I am currently able to send a config file via tftp and http to my spa504g phone and configure the lines for asterisk.
How do I setup a blind transfer button and a direct to voicemail buttom when talking to a caller?
I have read on the forum but am still lost.
Thank you for any help.
Aaron
02-21-2012 03:25 PM
Blind Transfer should already be on your phone. During a call press the right arrow on the navigation button. Blind transfer should be there.
You can use one of the PSK keys on the phone to create the direct to VM button. Look on page 69 of the guide below on instructions on how to make a custom key. http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa500_admin.pdf
02-21-2012 04:19 PM
Thanks for the Doc I am hoping for more details. I am not exactly sure how to setup.
Does anyone have an example script/configuration file already made for tftping to the phone to add a softkey?
02-21-2012 04:34 PM
Easy Enough. See attached. You will have to edit the PSK1 section. Just copy/paste the rest into your configuration file. This will put your blind transfer button on the first softkey when call is connected, and your custom key on the second soft key. You may have to make sure the bxfer start code is the same as the one in your Asterisk box.
