Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
7003
Tony Bagalini
Beginner
SPA504g w/ SPA500s speed dial asterisk
Hello I have a SPA504g that is connected to the SPA500s attendant console.
I have it working to monitor an extension and call the extension. (fnc=sd+blf+cp;sub=5401@192.168.1.111)
I can not figure out how to just use it dial phone external phone numbers - use it just for speed dials.
for example when you press key 1 have it dial a outside phone number like 8003102355
Any idea how to program this?
Thank you!!
1 REPLY 1
Patrick Born
Hi Tony,
If I understand you correctly, you don't want blf (busy lamp field) and cp (call pickup) capabilities, you just want sd (speed dial)
Change from this:
To this:
     fnc=sd;sub=5401@192.168.1.111
or to this:
     fnc=sd;sub=913615551212@192.168.1.111 [assuming 9 is a steering digit and you want to dial 1-361-555-1212]
You may find the following to be of use:
Patrick
You only need one reference document for all SPA phone firmware, information, and utilities.
