SPA514 + 500S Sidecar
CHRIS YEO
Hi guys,
Can someone verify that the 514 + sidecar is not configurable through CCA?  We are having an issue at a site and we are just configuring it using CLI (unsupported) for right now.
Thanks!
Chris
Hello Chris,
SPA500S is configurable with CCA as 514 with CCA 3.2.2. The SPA500DS is not.
You may check the supported devices on the following link for CCA 3.2.2 (the current release):
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_2_2/release/Notes/cca_3_2_2_relnotes.pdf
HTH,
Alex
*Please rate helpful posts
Hello Chris,
HTH,
Alex
