12-09-2010 04:18 AM - edited 03-21-2019 03:23 AM
Hello all.
I have two issues that I am rather stumped on.
1) Our system pre-pends the callers Name field with the type of call and duration. On our SNOMs, we see that information even when the caller is Anonymous/Withheld but it seems that if the SPA sees "Anonymous" it ignores any name field sent.
i.e the SIP trace shows:
From: "M0:0 queue anonymous"<sip:Anonymous@xx.xx.xx.xx.>
On our other phones we see "M0:0 queue anonymous" but on the SPA we just see "Anonymous" - quite annoying.
Is there anyway to stop it doing that.
2) We all use call waiting in the office but want to disable the tone/bleep that is made when a call is incoming. The flashing red light is sufficient. I tried to change all settings in the GUI but none had any affect.
Thanks!
01-04-2012 06:06 PM
Hi Matt,
I am having exaclty the same issue with Anonymous calls not displaying the hunt group or Agent group name. This issue appears to be confined to Cisco handsets.
Did you find a resolution for this? Appreciate any information you have discovered.
Thanks.
02-08-2012 10:47 AM
2) it should work, just navigate to refional tab in the web GUI and erase the line for call waiting.
1) is there an CLN as well as an CLI?
05-24-2012 04:52 AM
Hi Fredrik,
I have same issue with Anonymous calls.
Yes we have CLN as well an CLI.
Please advise.
Arun
