SPA525G2 Bluetooth Not Pairing
joshuaamyx
Hi all,
I'm having an issue with a 525G2.  It scans for bluetooth devices but never finds any.  When trying to pair from my iPhone to the Cisco, I get to a passcode but the passcode always fails.
I've captured the syslog and I'll post it here shortly.
Any ideas?
joshuaamyx
TS Detached; ts=39c888 tu=35e690(5), cb=1d1f8
+++ ts 0x369e10 clean 0 363530 3634a0 bcts:1 nRef:0
SIP_tcpRemoveTsItem 0 0x369e10
[tcpThread] evt 3 s->ucState 3
[0]SIP/TCP Idle
OP ext'd 7 152
OP ext'd 1 490
Start TmrJ:39c888,35e690(5,m=6)
Tmr J Fires
+++ ts 0x39c888 clean 0 363388 324ea0 bcts:0 nRef:0
regTimerCallBack 50 bTryAltReg 0
OP ext'd 6 145
#### create TS 1 0x369e10
SIP_tcpAddTsItem 0 0x369e10
OP ext'd 16 132
OP ext'd 1 491
[tcpThread] evt 2 s->ucState 3
RSE_DEBUG: set current addr of domain:prod.voipdnsservers.com to:d0499047:5062
RSE_DEBUG: 5 RSE_TRAVERSE
RSE_DEBUG: Domain: prod.voipdnsservers.com, type=HOST
RSE_DEBUG: Total Address:1, up addr:1, ref id:0, ref cnt:1
RSE_DEBUG: Current addr:208.73.144.71
RSE_DEBUG: curr timestamp::828771, pri:1, scnd:1
RSE_DEBUG: pri:0, addr: 208.73.144.71:5062, status=UP, visited=TRUE, ttl=-1, pri=PRIM
[tcpThread] evt 0 s->ucState 3
SIP_regTsEventProc 27
[0]RegOK. NextReg in 89 (1)
OP ext'd 1 492
TS Detached; ts=369e10 tu=35ec70(9), cb=2ece8
SIP_regTsEventProc 31
+++ ts 0x369e10 clean 0 363530 324ea0 bcts:1 nRef:0
[0]SIP/TCP Idle
OP ext'd 7 153
OP ext'd 1 493
Tmr J Fires
OP ext'd 6 146
OP ext'd 16 133
OP ext'd 1 494
RSE_DEBUG: curr timestamp::835782, pri:1, scnd:1
SIP_tsClientEventProc(): ts=369e10 tu=35ec70(9), cb=2ece8
OP ext'd 1 495
[0]SIP/TCP Idle
OP ext'd 7 154
OP ext'd 1 496
Tmr J Fires
OP ext'd 6 147
OP ext'd 16 134
OP ext'd 1 497
RSE_DEBUG: curr timestamp::842797, pri:1, scnd:1
[0]RegOK. NextReg in 88 (2)
OP ext'd 1 498
[0]SIP/TCP Idle
OP ext'd 6 148
SIP_tsCreateClient SIP_getNextHopTransportPar
OP ext'd 1 499
OP ext'd 1 500
TS:Reset TmrE to Max
SIP_tsClientEventProc(): ts=369e10 tu=35ef88(9), cb=2ece8
SIP_getAuthState callid=21cca3a5-9b81dd77@10.1.19.64 realm=asterisk type=0
OP ext'd 1 501
TS Detached; ts=369e10 tu=35ef88(9), cb=2ece8
OP ext'd 6 149
#### create TS 1 0x367c00
OP ext'd 1 502
OP ext'd 1 503
SIP_tsClientEventProc(): ts=367c00 tu=35ef88(9), cb=2ece8
[1]RegOK. NextReg in 3599 (1)
OP ext'd 1 504
TS Detached; ts=367c00 tu=35ef88(9), cb=2ece8
+++ ts 0x369e10 clean 0 363388 324ea0 bcts:1 nRef:0
RSE_DEBUG: rse_unref context: 0x36a1fc
+++ ts 0x367c00 clean 0 363530 3634a8 bcts:1 nRef:0
RSE_DEBUG: rse_unref context: 0x367fec
OP ext'd 7 155
OP ext'd 1 505
Start TmrJ:39c888,35e690(5,m=5)
OP ext'd 7 156
OP ext'd 1 506
Start TmrJ:39dc50,35e690(5,m=6)
Tmr J Fires
+++ ts 0x39c888 clean 0 363530 324ea0 bcts:0 nRef:0
Tmr J Fires
+++ ts 0x39dc50 clean 0 363388 363648 bcts:0 nRef:0
TS Detached; ts=39dc50 tu=35e690(5), cb=1d1f8
OP ext'd 6 150
OP ext'd 16 135
OP ext'd 1 507
RSE_DEBUG: curr timestamp::849828, pri:1, scnd:1
OP ext'd 1 508
OP ext'd 7 157
OP ext'd 1 509
Tmr J Fires
OP ext'd 6 151
OP ext'd 16 136
OP ext'd 1 510
RSE_DEBUG: curr timestamp::856843, pri:1, scnd:1
OP ext'd 1 511
[0]SIP/TCP Idle
OP ext'd 7 158
OP ext'd 1 512
Tmr J Fires
OP ext'd 7 159
OP ext'd 1 513
OP ext'd 6 152
OP ext'd 16 137
OP ext'd 1 514
RSE_DEBUG: curr timestamp::863856, pri:1, scnd:1
OP ext'd 1 515
Tmr J Fires
[0]SIP/TCP Idle
OP ext'd 7 160
OP ext'd 1 516
Tmr J Fires
OP ext'd 6 153
OP ext'd 16 138
OP ext'd 1 517
RSE_DEBUG: curr timestamp::870872, pri:1, scnd:1
OP ext'd 1 518
[0]SIP/TCP Idle
OP ext'd 7 161
OP ext'd 1 519
Tmr J Fires
OP ext'd 6 154
OP ext'd 16 139
OP ext'd 1 520
RSE_DEBUG: curr timestamp::877883, pri:1, scnd:1
[0]SIP/TCP Idle
OP ext'd 7 162
OP ext'd 1 522
Tmr J Fires
Dan Lukes
Unfortunately, Bluetooth subsystem disclose no syslog messages. So no one know neither what's nor why the BT is doing.
The issue may be caused by particular firmware version of either iPhone or SPA525G2.
Some iPhones models/firmware versions can be paired, but there are other issues as well so I consider your chances to get it working rather low. See SPA525G2, Bluetooth and iPhone 4S
I think my chances are nada at this point but hoped the community here might provide some additional insight.
The phone won't connect to any type of bluetooth device and its brand new.  I've performed several factory resets and have updated the bluetooth and regular firmwares to the latest versions.
Thanks for your links
Despite new it may be broken (following screenshot has been shooted just few minutes ago, phone is Samsung B2710):
Note it's just evidence it's possible to pair devices. BT connection is not so stable and reliable. We considered not to use SPA525G2 at all (I have one piece here for tests only).
