628
Highlighted
Beginner
SPA525G2 Firmware Upgrade
I am trying to upgrade the Firmware of my SPA525G2 from 7.5.2 to the latest one, however when I follow the instructions on logging into the Web Interface and click on the Firmware Tab, UI am unable to do so. When I login to the web interface there is no Firmware Tab for me to click on.
Leigh Kefford
1 REPLY 1
Highlighted
Advocate
I can't help you with missing tab, but you should consider to trigger upgrade by other methods.
For example, you can trigger upgrade by casual browser using URL:
http:///upgrade?http:///
You can use FTP or TFTP as firmware file source as well.
Another method - create provisioning file contaning statement and load such provisioning file into device.
Hope it help.
