03-13-2013 11:03 AM - edited 03-21-2019 07:06 AM
The previous thread on getting my VPN working between the UC540 and the SPA525G2 for a remote phone did the trick (thanks!).
My problem now is that my SPA525G2 phone keeps rebooting. It started as soon as I got the VPN working. It starts up and says "upgrading to spa525g-7-4-9c" and then reboots. The time between the message appearing and the reboot is awful fast.
I tried to debug things by moving the phone back to the hardwired connected to the UC540, and it still does the same thing.
I used an AC adapter for the phone, and went into the unit's menu and did a factory reset. So now the phone wasn't rebooting, but it wasn't connected to the UC540, either.
So I then tried reconnecting it to the UC540, and it starts rebooting again.
So then I did a firmware upgrade on the phone, using my PC, to spa525g-7-5-4-bt.bin, and that worked. But when I connected the phone to the UC540 again, it starts rebooting again with the same "upgrading to spa525g-7-4-9c" message.
Any ideas? The UC540 seems to really want the phone on the 7-4-9c. Not sure if there is a way to tell the UC540 to move up to 7-5-4?
Any input would be welcome.
03-13-2013 01:25 PM
Hello John,
I believe there is an issue downgrading back from 7.5.4 to a firmware lower than 7.5.2. (If I remember corretly.) I would suggest that you upgrade the phone load on your UC540 to 7.5.4, so you don't run into this issue.
Phoneload update can be done in CCA under "Maintenance", "phone load management". You will need the latest Software Pack on your PC which is running CCA. Or, you can download the specific phone load, and drag-and-drop the file onto the UC540 icon in the "Topology View" of CCA.
Thank you,
Darren
03-26-2013 08:00 AM
John,
I had the exact same issue. This is a bug in the new version. To clear it, open a terminal, enter global config mode, and use the following command set:
conf t
telephony-service
no service phone SPA525-Encryption-key-code TKIP
no create cnf-files
create cnf-files
end
write
Crazy, but it works. HTH.
~Kris
04-01-2013 09:51 AM
Thanks Kris, I will remember those steps you posted.
In the end, I did a factory reset on the UC540, and things started to work better.
03-17-2016 01:50 AM
We had this exact same problem this week. The command above did work but we then lost the softkeys on the 525G2 handsets.
Quickest was for us was to reset the system and copy the config back from flash to startup-config and reboot.
Softkeys and phones then worked.
Voicemail recovered from Backup.
