I have a problem with a SPA525G2. It doesn't register on the UC540 if its IP is from another range than the UC540. on the phone
ex: spa525 (10.10)----Router-----Unity (20.1).
if the phone is plugged directly into the unity, it works without problems.
UC540W-BRI-K9
SPA525 Firmware: 7.5.2a
IOS:15.1(4)M4b
CME: 8.6
Thanks.
Cristian
Maybe you need to configure option 150 in DHCp at the remote relocation.
Note: UC500 is not Unity.
Hi Paolo,
150 is configured, the phone gets the SEP file but then remains in connecting...and nothing happens.
if I turn on the VPN, it works without problems.
Thanks.
Hi Cristian,
Is the SPA525 local to the UC or is it a remote phone?
Thank you,
Jason Nickle
Hi Jason,
yes, it's a simple lab setup.
spa525 --- router --- uc540
Cristian
it worked over vpn so we can close the thread.
Thanks.
