10-15-2010 08:16 PM - edited 03-21-2019 03:08 AM
Hello Everybody,
Recently we purchase a couple of SPA525G2 phones, we´ve UC540 system ver 8.0.4, and 2 Video Cams 2300.
The Video Monitoring Feature is not available, How can i setup this.
Thanks in Advance.
Robert.
Solved! Go to Solution.
10-16-2010 04:41 AM
The CCA 2.2.5 has a wizard in the HOME drawer for configuring this and the built in help is pretty good.
Once you run the wizard, it will show up on your phone.
Since it's.a G2, make sure you define it as such in the Configuration drawer under telephony -> voice ((voice extensions tab).
If you want to see an example, look at LAB 16 here: https://supportforums.cisco.com/docs/DOC-9836
It's not a G2 but other than the model, should work the same.
Steve DiStefano
Technical Solutions Architect - Partner Sales, USA
Cisco Systems
7025 Kit Creek Road
Research Triangle Park
North Carolina, 27709
1.919.392.6219
sdistef@cisco. com
www.cisco.com/smb
10-16-2010 04:41 AM
Steve DiStefano
Cisco Systems
7025 Kit Creek Road
1.919.392.6219
sdistef@cisco. com
www.cisco.com/smb
