09-06-2011 03:18 PM - edited 03-21-2019 04:37 AM
SPA525G2
Software Version: 7.4.8
Bluetooth Firmware Version: 0.00.32a
When attempting to pair a Plantronics Voyager PRO UC B230 I receive the error, "Pairing Failed"
It worked twice, but I had to reset the phone and I could never get it to pair again. It was nice when it worked
I have tried through the phone's gui and the phones web page. I have power cycled and opened Cisco STAC support requests. We tried to downgrade the phoen's firmware, and upgrade the Plantronic's firmware - no help.
I am able to pair the Plantronics headset with my iphone, and my iphone with my SPA525G2.
Cisco SPA525G2 BT.log (Diagnostic log) follows;
00000000000000476328 bt 7 [BT]<btReadClientPkt>: Start Bluetooth Debug(Debug Log[1] Path[/tmp/usb/usbsda1] FileName [spa525g_bt.log] MaxSize [1024000] SampleRate [0] Level [0])
00000000000000476330 bt 7 [BT]<btMessageHandler>: Message = CMD_DEBUG_LOG_REQ
00000000000000477772 bt 7 [BT]<btReadClientPkt>: Headset name 405539A278FA
00000000000000477773 bt 7 [BT]<btMessageHandler>: Message = CMD_HEADSET_CHANGE_DEVICE_NAME
00000000000000477773 bt 7 [BT]<btReadClientPkt>: Application Mode = 0
00000000000000477774 bt 7 [BT]<btMessageHandler>: Message = CMD_CONFIG_APPLICATION_MODE
00000000000000477775 bt 7 [BT]<btReadClientPkt>: Headset Pin Code 0000
00000000000000477776 bt 7 [BT]<btMessageHandler>: Message = CMD_HEADSET_CONFIG_PIN_CODE
00000000000000477776 bt 7 [BT]<btMessageHandler>: Message = REGISTER_HISTORY_DEVICE_REQ_ASY
00000000000000477777 bt 7 [BT]<btMessageHandler>: Message = CMD_ACTIVATE_REQUEST
00000000000000477778 bt 7 [BT]<sendMsgToChip>: write 'VD_CHIP_STATE_REQ#' into /dev/ttyS1
00000000000000477779 bt 7 [BT]<btRespClient>: Message= CMD_ACTIVATE_RESPONSE, status= 0
00000000000000477781 bt 7 [BT]<sendMsgToChip>: write 'VD_RESET_CHIP_REQ:1#' into /dev/ttyS1
00000000000000477898 bt 7 [BT]<sendMsgToChip>: write 'VD_ACTIVATE_REQ#' into /dev/ttyS1
00000000000000477899 bt 7 [BT]<sendMsgToChip>: write 'EventPowerOn#' into /dev/ttyS1
00000000000000477901 bt 7 [BT]<startActivateProcess>: auto-connect is turn on
00000000000000477902 bt 7 [BT]<sendMsgToChip>: write 'VD_CONFIG_APP_MODE:0#' into /dev/ttyS1
00000000000000477903 bt 7 [BT]<sendMsgToChip>: write 'EventChangeLocalName:405539A278FA#' into /dev/ttyS1
00000000000000477905 bt 7 [BT]<sendMsgToChip>: write 'EventConfigPinCode:0000#' into /dev/ttyS1
00000000000000477906 bt 7 [BT]<sendMsgToChip>: write 'VD_AUTO_CONNECT_START_TIMER:30#' into /dev/ttyS1
00000000000000479010 bt 7 [BT]<btMessageHandler>: Message = CMD_SEARCH_REQUEST_ASYNC
00000000000000479014 bt 7 !!VD_INQUIRY_SCAN_REQ!!
00000000000000479015 bt 7 [BT]<sendMsgToChip>: write 'VD_INQUIRY_SCAN_REQ#' into /dev/ttyS1
00000000000000480815 bt 7 [BT]<btProcessUartMessage>: <VD_INQUIRY_SCAN_RES> End!!
00000000000000480815 bt 7 [BT]<btRespClient>: Message= CMD_SEARCH_RESPONSE_ASYNC, status= 0
00000000000000480816 bt 7 [BT]<btProcessUartMessage>: <VD_INQUIRY_SCAN_RES>auto-connect is turn on
00000000000000480817 bt 7 [BT]<btProcessUartMessage>: Scan Complete
00000000000000480818 bt 7 [BT]<btMessageHandler>: Message = CMD_GET_SEARCH_RESULT_REQUEST
00000000000000480818 bt 7 [BT]<btRespClient>: Message= CMD_GET_SEARCH_RESULT_RESPONSE, status= 0
00000000000000482003 bt 7 [BT]<btMessageHandler>: Message = REGISTER_HISTORY_DEVICE_REQ_ASY
00000000000000482008 bt 7 [BT]<btMessageHandler>:addr=00:23:7F:B6:4A:27, name=Voyager PRO UC v2,, pin=0000, auto=1
00000000000000482008 bt 7 [BT]<btMessageHandler>: Message = CMD_CONNECT_REQUEST_ASYNC
00000000000000482025 bt 7 [BT]<sendMsgToChip>: write 'VD_SLC_CONNECT_REQ:0x00230x7F0xB64A27:C4#' into /dev/ttyS1
00000000000000482026 bt 7 [BT]<sendMsgToChip>: write 'VD_AUTO_CONNECT_STOP_TIMER#' into /dev/ttyS1
00000000000000482027 bt 7 [BT]<btMessageHandler>: <BT_CMD_CONNECT_REQ>auto-connect is turn off
00000000000000482485 bt 7 [BT]<btProcessUartMessage>:VD_SLC_CONNECT_RES Fail Status:4
00000000000000482486 bt 7 [BT]<btRespClient>: Message= CMD_CONNECT_RESPONSE_ASYNC, status= 0
00000000000000482489 bt 7 [BT]<btProcessUartMessage>: <VD_SLC_CONNECT_RES>auto-connect is turn on
00000000000000482490 bt 7 [BT]<sendMsgToChip>: write 'VD_AUTO_CONNECT_START_TIMER:15#' into /dev/ttyS1
00000000000000482491 bt 7 [BT]<btMessageHandler>: Message = REGISTER_HISTORY_DEVICE_REQ_ASY
00000000000000482794 bt 7 [BT]<btMessageHandler>: Message = CMD_FIRMWATE_VERSION_REQUEST
00000000000000482795 bt 7 [BT]<btRespClient>: Message= CMD_FIRMWATE_VERSION_RESPONSE, status= 0
09-08-2011 07:11 AM
Hi Brook;
Quick question, which BT mode you have the SPA525G set to? (phone, headset, both)...try setting it to headset.
Please note the phone supports just one BT device at a time, i.e. headset or phone, not both.
Alberto
09-16-2011 07:09 AM
The Voyager UC V2 is Plantronics newest, best selling hands-free headset.
The Cisco SPA525G2 is Cisco's best sellign VOIP phone.
The Plantronics headset will not pair with any Cisco SPA525G2 with the 7.4.8 firmware.
The only compatable Cisco SPA525G2 firmware we have discovered is 7.4.7.
We would be greatful if you could fix this in the next update.
Thanks.
09-16-2011 07:27 AM
I believe I saw that there is a 7.4.9 firmware out for the SPA525G/G2 that also includes a Bluetooth firmware update as well. I cannot speak to what impact that will have, just pointing it out.
09-16-2011 07:36 AM
Bill,
Thanks for the heads up.
I just saw the 7.4.9-bt update after I posted and have applied the update via the phone's GUI.
The 7.4.9-bt firmware does not resolve the issue. The same pairing issues remain.
09-16-2011 08:00 AM
Now I am stuck with Bluetooth formware Ver 0.34 that came with Phone firmware Ver 7.4.9 and I can roll the phoen firmware back, but not the bluetooth. Ugh.
11-02-2011 10:24 AM
Updated to firmware 7.4.9C and still cannot pair.
Cisco, can you please fix this?
Im going to try to downgrade to an earlier Bluetooth version on the SPA525G2 if it will allow it - back to a Bluetooth version that works.
