SPA525G2 - Time Format and Call Progress Tones
xilocommsltd
Hello.
Can any one advise how I can change the date format from MM/DD to DD/MM - we'd prefer the UK format.
Also, does anyone have the settings for UK tones instead of US ones?
Documentation on both of these features is quite lacking.
Finally, is there a way to change the format or wrap the NAME value that is shown? Some of ours get truncated.
2 Accepted Solutions
Steven Howes
Here are the full UK tones, should work for most models. It's provisioning XML, but you can copy/paste the values into the fields if you're doing it by hand:
350@-19,440@-22;10(*/0/1+2)
420@-16;10(*/0/1)
520@-19,620@-19;10(*/0/1+2)
400@-20;10(.375/.375/1)
400@-20;10(*/0/1)
480@-10,620@0;10(.125/.125/1+2)
400@-20,450@-20;*(.4/.2/1+2,.4/2/1+2)
440@-10;30(.3/9.7/1)
600@-16;1(.25/.25/1)
950@-16,1400@-16,1800@-16;20(.330/0/1,.330/0/2,.330/0/3,0/1/0)
914@-16,1371@-16,1777@-16;20(.274/0/1,.274/0/2,.380/0/3,0/4/0)
914@-16,1371@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)
985@-16,1371@-16,1777@-16;20(.380/0/1,.274/0/2,.380/0/3,0/4/0)
350@-19,440@-22;10(.75/.75/1+2)
350@-19,440@-19;2(.2/.2/1+2);10(*/0/1+2)
600@-19;*(.1/.1/1,.1/.1/1,.1/9.5/1)
350@-19;20(.1/.1/1,.1/9.7/1)
397@-19,507@-19;15(0/2/0,.2/.1/1,.1/2.1/2)
600@-16;.3(.05/0.05/1)
600@-19;.2(.05/0.05/1)
60(.4/.2,.4/2)
60(1/2)
60(.25/.25,.25/.25,.25/1.75)
60(.4/.8)
60(2/4)
60(.2/.4,.2/.4,.2/4)
60(.4/.2,.4/.2,.4/4)
60(0.25/9.75)
60(.4/.2,.4/2)
I got that from old Sipura documentation, which somewhere between then and Linksys and/or Cisco has been 'lost'.
Cant help with MM/DD problem, but you may find this useful for daylight savings..
start=3/-1/7/1:0:0;end=10/-1/7/2:0:0;save=1:0:0
Yes
Hope this is of use.
S
In the user tab, under supplementary services, there's the Date Format to switch the month and day.
5 Replies 5
nseto
Level 6
Level 6
Regarding the tones, you can find the info at http://www.3amsystems.com/wireline/tone-search.htm
Regarding the MM/DD switcharound, that feature will be provided in a future release.  Probably Spring 11'.
Steven Howes
420@-16;10(*/0/1)
400@-20;10(*/0/1)
60(.4/.2,.4/2)
60(1/2)
60(.4/.8)
60(2/4)
60(0.25/9.75)
60(.4/.2,.4/2)
Yes
S
xilocommsltd
Thanks for everyone's help - very much appreciated.
One last query. One of our SIP systems uses * to define clients.
i.e XXXX*YYYY = XXXX being the client prefix, YYYY being the extension.
So, if we want to call another client, we could dial 0565*3423 but the phone says "Invalid Number". Have tried this on a Snom without any problems and have checked my dial plan on the SPA without any joy.
Will the * get interpreted by the SPA as some sort of shortcut and then fail?
Thanks!
Can you try with your dial plan expliciting having xxxx*xxxx to see if that corrects this?  It should work.  If not, send the htm config (just log into the web page as admin/advanced and save as htm.  Also the debug log of the call.
