09-17-2012 11:06 AM - edited 03-21-2019 06:18 AM
I am unable to update the time zone uisng a xml file that is downloaded from the Broadsoft platform. When When i extract the SPACFG.xml file from the phone the timezone field displays thsi error: "<Time_Zone group="Regional/Miscellaneous">[LABEL NOT FOUND]</Time_Zone>.
Attached is the SPACFG.xm phone configuration file and the 509system.xml that the phone downloads form the server during auto configuration process.
09-20-2012 03:55 PM
I'm running 7.5.1a and my xml file pulled from the unit does show GMT -8.00 which matches what is seen the web UI.
What do you see in the web UI for this parameter?
09-21-2012 05:53 AM
Can be a notation error in your xml. Try to change this:
with:
Regards.
