SPA8000 and UC560
focusonit
I've followed this guide and have registered the SPA8000 with the UC.
https://supportforums.cisco.com/docs/DOC-9465
I can make internal calls to existing  IP extensions from the FXS port (and it identifies as the registered extension) however if I try to call the FXS ports I get "number unknown" - am I missing something basic to make the existing setup see the new extensions?
I havne not registered the ports with voice mail - I just want them to be used for faxes with a PRI
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 10
max-pool 10
voice register dn  1
number 253
no-reg
voice register pool  1
id mac 687F.4D8C.C084
number 1 dn 1
dtmf-relay rtp-nte
voice-class codec 1
username 100 password ext100
no vad
focusonit
Factory reset the test box and it worked perfectly for the first two lines - Lines now 3-8 wont register
The config done via the SPA800 is all identical other than the registered number.
voice service voip
sip
registrar server
mode cme
max-dn 10
max-pool 10
voice register dn  1
number 205
no-reg
voice register dn  2
number 206
no-reg
voice register dn 3
number 207
no-reg
voice register dn  4
number 208
no-reg
voice register dn  5
number 209
no-reg
voice register dn  6
number 210
no-reg
number 1 dn 1
number 2 dn 2
number 3 dn 3
number 4 dn 4
number 5 dn 5
number 6 dn 6
dtmf-relay rtp-nte
voice-class codec 1
no vad
