Showing results forĀ
Search instead forĀ
Did you mean:Ā
SPA900 Blinks Red and Green
PetesGuide
I have an SPA9000 version 2 that behaves strangely. It's light pattern does not match any of those in the documents here:
Red for 1 second
Green for .5 second
Off for .5 second
Green for .5 second
Off for .5 second
Green for .5 second
Off for 2 seconds
(repeats)
The  phone is only able to connect to the box for about 1.5 seconds starting with the second green light. Not even close to enough time to set or report anything.
The Ethernet activity lights on the SPA and the switch match this length.
And sometimes, after trying to use the IVR interface, the Tel1 port stops responding, and  the  Tel2 port then provides access for that same 1.5 seconds.
Is this SOS  mode or something different?
0 Replies 0
