02-08-2012 03:28 AM - edited 03-21-2019 05:18 AM
Hello.
I have a spa9000 and today suddenly I saw that the power led going from red to green and the Ethernet flash 2 times....
it can't connected to switch even from Ethernet port or internet...
It have not dial tone to analog devise phone 1 for reset...
Can you please advise what to do??
Thanks a lot
02-10-2012 04:53 PM
See if there's IVR, by pressing **** from the analog phone connected to the unit. If no IVR, it's dead.
If IVR, then enter RESET from the phone and see if the unit can be reset.
02-11-2012 04:33 AM
I press **** from phone 1 with analog phone and also from phone 2 but no IVR .
I press the reset code but the unit didn't respond. If any recovery software exist???
Also the spa didn't respond to Ethernet connection. The Ethernet led at the switch or at the pc didn't power up.
02-13-2012 08:53 AM
From your description, it's dead.
02-13-2012 11:33 AM
when i plug the power after 5-10 sec the power led blink 2 times and the ethernet flash one... Maybe that help someone... I read that this device have a led code if it si in recovery or flash mode... It's real? Thanks for help anyway!
10-31-2013 05:07 PM
I just came home and noticed i am having the exact same problem. i switched the 5v power supply with another i had at home, and the PBX is back to normal. The power supply was warmer than normal.
