Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
3108
Highlighted
Beginner
SPA9000 Won't receive inbound SIP calls
Hi Guys,
We have a client with an SPA900, SPA400 and 4x SPA942s. They signed up for a new SIP service through Nexvortex. All outbound calls work great, but an inbound call to either of their DIDs fails. The DIDs have been provisioned and I can see calls hitting SYSLOG. The error I receive is as follows:
08-03-2011          16:00:00               Local0.Info          192.168.1.4
08-03-2011          16:00:00               Local0.Info          192.168.1.4         [2]<<66.23.129.253:5060(445)
08-03-2011          16:00:00               Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(692)
08-03-2011          16:00:00               Local0.Info          192.168.1.4         pri--REJECT Call(reason=39)-->pub
08-03-2011          15:59:58               Local2.Debug     192.168.1.52       [0]RegOK. NextReg in 29 (1)
08-03-2011          15:59:51               Local0.Info          192.168.1.4
08-03-2011          15:59:51               Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(611)
Currently, we have a contact rule setup to send each DID to a specific extension. If I remove the Contact List Rule, the phones still will not ring when an inbound call is received.
Any ideas?
Madison
Everyone's tags (3)
5 REPLIES 5
Beginner
This is what I am seeing from syslog when I place a call to the SPA 9000. For reference 192.168.1.4 is the PBX (SPA 9000). Any help here would be much appreciated.
Record-Route: <sip:17736445362@66.23.129.253:5060;nat=yes;ftag=a9d5ed0-13c4-4e3adfe5-6fb53347-577f1e44;lr=on>
From: <17084660658>;tag=a9d5ed0-13c4-4e3adfe5-6fb53347-577f1e44
To: <17736445362>
Call-ID: CXC-36-6b334650-a9d5ed0-13c4-4e3adfe5-6fb53347-683fd4d6@208.94.157.10
CSeq: 1 INVITE
Via: SIP/2.0/UDP 66.23.129.253:5060;branch=z9hG4bKa2ff.1bccbaa.0
Via: SIP/2.0/UDP 208.94.157.10:5060;branch=z9hG4bK-8e4a9-4e3adfe5-6fb53347-28f0cb2d
Max-Forwards: 16
P-Asserted-Identity: <>17084660658@cxc.dashcs.com:5060>
Content-Disposition: session;handling=required
Contact: <17084660658>
Min-SE: 900
Session-Expires: 1800
Content-Type: application/sdp
Content-Length: 238
v=0
o=Acme_UAS 0 1 IN IP4 208.94.157.10
s=SIP Media Capabilities
c=IN IP4 208.94.157.10
t=0 0
m=audio 20062 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
2011-08-04 13:07:30        Local0.Info          192.168.1.4
2011-08-04 13:07:30        Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(621)
2011-08-04 13:07:30        Local7.Debug     192.168.1.4         SIP/2.0 100 Trying
To: <sip:17736445362@66.23.129.253:5060>
CSeq: 1 INVITE
Record-Route: <17736445362>
Server: Linksys/SPA9000-6.1.5
Allow-Events: talk, hold, conference, x-spa-cti
Content-Length: 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [5060]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16402]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16403]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16404]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16405]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [5060]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16402]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16403]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16404]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16405]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [5060]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16402]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16403]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16404]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16405]STUN trying 2
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [5060]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16402]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16403]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16404]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16405]STUN trying 3
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [5060]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16402]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16403]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16404]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16405]STUN trying 4
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [5060]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16402]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16403]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16404]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16405]STUN trying 5
2011-08-04 13:07:34        Local2.Debug     192.168.1.56       [0]RegOK. NextReg in 29 (1)
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [5060]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16402]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16403]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16404]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16405]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [5060]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16402]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16403]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16404]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16405]STUN trying 7
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [5060]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16402]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16403]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16404]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16405]STUN trying 8
2011-08-04 13:07:40        Local2.Debug     192.168.1.4         [2:0]STUN Failed
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]->192.168.1.55:5060(644)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         INVITE sip:102@192.168.1.55:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.4:6060;branch=z9hG4bK-b05c6c34;rport
To: <102>
Call-ID: e2332f5c-b181cff7@192.168.1.4
CSeq: 101 INVITE
Max-Forwards: 70
Contact: "" <17084660658>
Expires: 240
User-Agent: Linksys/SPA9000-6.1.5
Content-Length: 67
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
v=0
o=-   IN IP4 173.161.44.5
s=-
c=IN IP4 173.161.44.5
t=0 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]<<192.168.1.55:5060(292)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         SIP/2.0 100 Trying
To: <sip:102@192.168.1.4>
CSeq: 101 INVITE
Server: Linksys/SPA942-6.1.5(a)
Content-Length: 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]<<192.168.1.55:5060(373)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         SIP/2.0 488 Not Acceptable Here
To: <sip:102@192.168.1.4>;tag=d2d4205569b90bd9i0
CSeq: 101 INVITE
Warning: 304 spa "Media type not available"
Content-Length: 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]->192.168.1.55:5060(454)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         ACK sip:102@192.168.1.55:5060 SIP/2.0
To: <102>;tag=d2d4205569b90bd9i0
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         pri--REJECT Call(reason=39)-->pub
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(702)
To: <sip:17736445362@66.23.129.253:5060>;tag=e1d1f9009ab6f2a4i2
CSeq: 1 INVITE
Content-Length: 006
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [2]<<66.23.129.253:5060(455)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         ACK sip:17736445362@173.161.44.5;transport=udp SIP/2.0
To: <17736445362>;tag=e1d1f9009ab6f2a4i2
CSeq: 1 ACK
User-Agent: Sip EXpress router(0.9.6 (x86_64/linux))
Content-Length: 0
2011-08-04 13:07:40        Local2.Debug     192.168.1.4         DLG Terminated 3a43f8
2011-08-04 13:07:40        Local2.Debug     192.168.1.4         Sess Terminated 3c1bb4
2011-08-04 13:07:50        Local3.Debug     192.168.1.4         [3]RegOK. NextReg in 28 (1)
2011-08-04 13:07:50        Local0.Info          192.168.1.4         +++ full fxo report
2011-08-04 13:07:50        Local0.Info          192.168.1.4         +++[3]fxo port mask = 0
2011-08-04 13:07:50        Local2.Debug     192.168.1.4         [3]SubOK. NextSub in 29 (1)
2011-08-04 13:07:54        Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(484)
2011-08-04 13:07:54        Local7.Debug     192.168.1.4         SUBSCRIBE sip:8888@192.168.15.18:5090 SIP/2.0
Via: SIP/2.0/UDP 173.161.44.5:5060;branch=z9hG4bK-1786c7de;rport
To: ""
Call-ID: 8d91ce4e-2db97380@192.168.1.4
CSeq: 59623 SUBSCRIBE
Max-Forwards: 70
Contact: ""
Expires: 30
Event: message-summary
Content-Length: 0
2011-08-04 13:07:54        Local0.Info          192.168.1.4         [2]<<66.23.129.253:5060(383)
2011-08-04 13:07:54        Local7.Debug     192.168.1.4         SIP/2.0 500 I'm terribly sorry, server error occurred (1/SL)
Via: SIP/2.0/UDP 173.161.44.5:5060;branch=z9hG4bK-1786c7de;rport=5060
To: "" ;tag=9c6a9fdfd4d16ebaa52f34c4c528cbe5.a691
Server: nVSIP 12.02.01
Content-Length: 0
2011-08-04 13:07:54        Local2.Debug     192.168.1.4         [2]SUBS:Failed(43). Retry in 30s
Beginner
Now it appears that roughly 1/20 calls are being received.
Beginner
Does anyone know what the message
means?
Beginner
I asked my carrier to do a trace and they said my system is rejecting incoming calls with a "484 rejection"
Any help would be much appreciated.
Beginner
The solution ended up being an issue with the SPA9000 and it's communication with the Nexvortex stun server. I switched to the 3cx stun server and everything started working fine.
