Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
3285
madisontmajor
Beginner
SPA9000 Won't receive inbound SIP calls
Hi Guys,
We have a client with an SPA900, SPA400 and 4x SPA942s. They signed up for a new SIP service through Nexvortex. All outbound calls work great, but an inbound call to either of their DIDs fails. The DIDs have been provisioned and I can see calls hitting SYSLOG. The error I receive is as follows:
08-03-2011          16:00:00               Local0.Info          192.168.1.4
08-03-2011          16:00:00               Local0.Info          192.168.1.4         [2]<<66.23.129.253:5060(445)
08-03-2011          16:00:00               Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(692)
08-03-2011          16:00:00               Local0.Info          192.168.1.4         pri--REJECT Call(reason=39)-->pub
08-03-2011          15:59:58               Local2.Debug     192.168.1.52       [0]RegOK. NextReg in 29 (1)
08-03-2011          15:59:51               Local0.Info          192.168.1.4
08-03-2011          15:59:51               Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(611)
Currently, we have a contact rule setup to send each DID to a specific extension. If I remove the Contact List Rule, the phones still will not ring when an inbound call is received.
Any ideas?
Madison
5 REPLIES 5
madisontmajor
Beginner
This is what I am seeing from syslog when I place a call to the SPA 9000. For reference 192.168.1.4 is the PBX (SPA 9000). Any help here would be much appreciated.
Record-Route: <sip:17736445362@66.23.129.253:5060;nat=yes;ftag=a9d5ed0-13c4-4e3adfe5-6fb53347-577f1e44;lr=on>
From: <17084660658>;tag=a9d5ed0-13c4-4e3adfe5-6fb53347-577f1e44
To: <17736445362>
Call-ID: CXC-36-6b334650-a9d5ed0-13c4-4e3adfe5-6fb53347-683fd4d6@208.94.157.10
CSeq: 1 INVITE
Via: SIP/2.0/UDP 66.23.129.253:5060;branch=z9hG4bKa2ff.1bccbaa.0
Via: SIP/2.0/UDP 208.94.157.10:5060;branch=z9hG4bK-8e4a9-4e3adfe5-6fb53347-28f0cb2d
Max-Forwards: 16
P-Asserted-Identity: <>17084660658@cxc.dashcs.com:5060>
Content-Disposition: session;handling=required
Contact: <17084660658>
Min-SE: 900
Session-Expires: 1800
Content-Type: application/sdp
Content-Length: 238
v=0
o=Acme_UAS 0 1 IN IP4 208.94.157.10
s=SIP Media Capabilities
c=IN IP4 208.94.157.10
t=0 0
m=audio 20062 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
2011-08-04 13:07:30        Local0.Info          192.168.1.4
2011-08-04 13:07:30        Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(621)
2011-08-04 13:07:30        Local7.Debug     192.168.1.4         SIP/2.0 100 Trying
To: <sip:17736445362@66.23.129.253:5060>
CSeq: 1 INVITE
Record-Route: <17736445362>
Server: Linksys/SPA9000-6.1.5
Allow-Events: talk, hold, conference, x-spa-cti
Content-Length: 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [5060]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16402]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16403]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16404]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16405]STUN trying 0
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [5060]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16402]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16403]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16404]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16405]STUN trying 1
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [5060]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16402]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16403]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16404]STUN trying 2
2011-08-04 13:07:30        Local2.Debug     192.168.1.4         [16405]STUN trying 2
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [5060]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16402]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16403]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16404]STUN trying 3
2011-08-04 13:07:31        Local2.Debug     192.168.1.4         [16405]STUN trying 3
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [5060]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16402]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16403]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16404]STUN trying 4
2011-08-04 13:07:32        Local2.Debug     192.168.1.4         [16405]STUN trying 4
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [5060]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16402]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16403]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16404]STUN trying 5
2011-08-04 13:07:33        Local2.Debug     192.168.1.4         [16405]STUN trying 5
2011-08-04 13:07:34        Local2.Debug     192.168.1.56       [0]RegOK. NextReg in 29 (1)
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [5060]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16402]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16403]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16404]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16405]STUN trying 6
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [5060]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16402]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16403]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16404]STUN trying 7
2011-08-04 13:07:36        Local2.Debug     192.168.1.4         [16405]STUN trying 7
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [5060]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16402]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16403]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16404]STUN trying 8
2011-08-04 13:07:38        Local2.Debug     192.168.1.4         [16405]STUN trying 8
2011-08-04 13:07:40        Local2.Debug     192.168.1.4         [2:0]STUN Failed
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]->192.168.1.55:5060(644)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         INVITE sip:102@192.168.1.55:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.4:6060;branch=z9hG4bK-b05c6c34;rport
To: <102>
Call-ID: e2332f5c-b181cff7@192.168.1.4
CSeq: 101 INVITE
Max-Forwards: 70
Contact: "" <17084660658>
Expires: 240
User-Agent: Linksys/SPA9000-6.1.5
Content-Length: 67
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
v=0
o=-   IN IP4 173.161.44.5
s=-
c=IN IP4 173.161.44.5
t=0 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]<<192.168.1.55:5060(292)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         SIP/2.0 100 Trying
To: <sip:102@192.168.1.4>
CSeq: 101 INVITE
Server: Linksys/SPA942-6.1.5(a)
Content-Length: 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]<<192.168.1.55:5060(373)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         SIP/2.0 488 Not Acceptable Here
To: <sip:102@192.168.1.4>;tag=d2d4205569b90bd9i0
CSeq: 101 INVITE
Warning: 304 spa "Media type not available"
Content-Length: 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [pxy]->192.168.1.55:5060(454)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         ACK sip:102@192.168.1.55:5060 SIP/2.0
To: <102>;tag=d2d4205569b90bd9i0
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
2011-08-04 13:07:40        Local0.Info          192.168.1.4         pri--REJECT Call(reason=39)-->pub
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(702)
To: <sip:17736445362@66.23.129.253:5060>;tag=e1d1f9009ab6f2a4i2
CSeq: 1 INVITE
Content-Length: 006
2011-08-04 13:07:40        Local0.Info          192.168.1.4         [2]<<66.23.129.253:5060(455)
2011-08-04 13:07:40        Local7.Debug     192.168.1.4         ACK sip:17736445362@173.161.44.5;transport=udp SIP/2.0
To: <17736445362>;tag=e1d1f9009ab6f2a4i2
CSeq: 1 ACK
User-Agent: Sip EXpress router(0.9.6 (x86_64/linux))
Content-Length: 0
2011-08-04 13:07:40        Local2.Debug     192.168.1.4         DLG Terminated 3a43f8
2011-08-04 13:07:40        Local2.Debug     192.168.1.4         Sess Terminated 3c1bb4
2011-08-04 13:07:50        Local3.Debug     192.168.1.4         [3]RegOK. NextReg in 28 (1)
2011-08-04 13:07:50        Local0.Info          192.168.1.4         +++ full fxo report
2011-08-04 13:07:50        Local0.Info          192.168.1.4         +++[3]fxo port mask = 0
2011-08-04 13:07:50        Local2.Debug     192.168.1.4         [3]SubOK. NextSub in 29 (1)
2011-08-04 13:07:54        Local0.Info          192.168.1.4         [2]->66.23.129.253:5060(484)
2011-08-04 13:07:54        Local7.Debug     192.168.1.4         SUBSCRIBE sip:8888@192.168.15.18:5090 SIP/2.0
Via: SIP/2.0/UDP 173.161.44.5:5060;branch=z9hG4bK-1786c7de;rport
To: ""
Call-ID: 8d91ce4e-2db97380@192.168.1.4
CSeq: 59623 SUBSCRIBE
Max-Forwards: 70
Contact: ""
Expires: 30
Event: message-summary
Content-Length: 0
2011-08-04 13:07:54        Local0.Info          192.168.1.4         [2]<<66.23.129.253:5060(383)
2011-08-04 13:07:54        Local7.Debug     192.168.1.4         SIP/2.0 500 I'm terribly sorry, server error occurred (1/SL)
Via: SIP/2.0/UDP 173.161.44.5:5060;branch=z9hG4bK-1786c7de;rport=5060
To: "" ;tag=9c6a9fdfd4d16ebaa52f34c4c528cbe5.a691
Server: nVSIP 12.02.01
Content-Length: 0
2011-08-04 13:07:54        Local2.Debug     192.168.1.4         [2]SUBS:Failed(43). Retry in 30s
Now it appears that roughly 1/20 calls are being received.
Does anyone know what the message
means?
I asked my carrier to do a trace and they said my system is rejecting incoming calls with a "484 rejection"
Any help would be much appreciated.
The solution ended up being an issue with the SPA9000 and it's communication with the Nexvortex stun server. I switched to the 3cx stun server and everything started working fine.
