01-24-2012 11:49 AM - edited 03-21-2019 05:14 AM
My SPA942 is connected to to PBX from german manufactrer.
I can call with my SPA942 and pick up calls from outside without any problems.
But if I try to get other local phone, my PBX needs following sequence **1 (for local connection "1").
But after second asterix my SPA942 goes into error state "Invalid number".
Is it possible to forward this asterix sequence to my PBX?
(any configuration recommedations???)
Thanks for your help.
Solved! Go to Solution.
01-24-2012 01:23 PM
You just need to edit the dial plan. You can download and refer to the admin guide for this info.
By default, the dial plan allows for one star and then two digits afterward. You'd need to edit this.
01-24-2012 01:23 PM
01-25-2012 08:48 AM
In fact it was very simple job. All I had to do is, to add to my dial plan sequence **[1-9].
Now it works fine.
