12-29-2010 03:08 AM - edited 03-21-2019 03:27 AM
Have a question:
Have a numbers SPA942 with a group number and a DID number.
If I want to make a call transfer between two phones, I must dial the full number to the C-user. reason is that the A-part comes from the PSTN gateway.
Is it possible to configure your phone so you only need to dial the last digit of the number?
//Niklas
Solved! Go to Solution.
01-14-2011 07:39 AM
Hi Niklas,
You can configure it in the Dial Plan:
For example if you want to dial for the number 123456789 but you want only to dial the last digit you can do it.
(<9:123456789>| "rest of your dial plan configuration")
Please make a backup of your actual dial plan before to do the tests.
Regards.
Andrey Cassemiro.
01-12-2011 09:50 AM
Short dialing codes is something you would usually configure in your PBX.
In Asterisk you could do something like
exten => XX,1,Dial(SIP/01234567${EXTEN})
If you would dial number '89', SIP device 0123456789 would be dialed.
01-14-2011 07:39 AM
Hi Niklas,
Regards.
Andrey Cassemiro.
01-14-2011 07:45 AM
ThanksThis will help
//Niklas
01-14-2011 09:03 AM
Hi Again,
A stuppied question.
How should the dial plan look if I would like to have three digit extension (100)?
Thanks Niklas
01-14-2011 09:42 AM
Hi Niklas,
It would be almost the same:
(<100:123456789100>| "rest of your dial plan configuration")
You can play as you want with the Dial Plan as it is "based" in regular expressions.
Please, refer to the SPA Phones Admin Guide on Page 198, there you can taste the power.
Best regards.
Andrey Cassemiro.
01-28-2011 12:27 AM
Hi again,
Have very stupid question.
Have added following dial plan : (<100:123456789100>| (<101:123456789101>|
The problem is that I can't call any other number, should I add the default part also ?
(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
Please need assistance.
Many Thanks Niklas
01-28-2011 04:10 AM
Hi Niklas,
Yes, you must complete the Dial Plan, (<100:123456789100>|<101:123456789101>|*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
In the example above it is using your configurations and the default Dial Plan.
Regards.
Andrey Cassemiro.
