SPA962 Backlit Time Out Not Working
amir.shenas
The SPA962 with the latest firmware (6.1.3a) exhibt an issue with the back light timer. I can set the time in the Preference>Back Light Timer and save the setting. However, if I check it again the value (i.e. 10, or 30..) it's not there. Also "Screen Save Mode" parametere work fine. In comparison to the other SPAs, the SPA942 has default values thant one can select and the values are followed by an "s". Has any one noticed this issue with the new F/W?
Patrick Born
The back light timer configuration problem is assigned to CDETS# CSCsu50551
In the interim, you can accomplish the equivalent functionality as follows:
Phone's web-ui > Phone tab > General > Screen Saver Icon: Power Save Screen
Thanks for taking the time to let us know.
Patrick
