07-28-2011 01:59 AM - edited 03-21-2019 04:24 AM
after a change of setting (an extension in theSPA932 consolle) the phone don't reboot correctly ( the display blink, all the lights are turn on and is unreachable from the network).... i have remove the SPA932, use an external power supply... but no luck...
there is something to do?
Thnaks
07-29-2011 02:53 PM
Are you able to factory reset the phone from the phone menu?
09-01-2011 03:46 AM
Hi NSeto,
I have the same problem. I'm not able to enter the menu. The Phone is like a pulsar with the screen and the top 4 led's.
Is there a standard key combination to set factory defaults during power up?
Thx,
Carlo
