Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
284
Highlighted
Beginner
Speed dial CISCO SPA509G disappears after a while
Hello everybody,
I'm having some issues with several VoIp phones, more precisely speed dial configuration in Phone tab (gui).
My configuration in extended function field is :
fnc=sd;ext=10@$PROXY;vid=1;nme=Bob
fnc=speed dial
vid=current phone extension
nme=Bob
Sometimes i need to add in the field Short Name: the user name (because i doesn't appears next to speed dial button on the phone screen).
After a day or two the speed dial link it disappears from Phone tab configuration and from the phone screen. (see attachement)
I'am using Kerio Operator as a SIP provider.
Everyone's tags (1)
1 REPLY 1
Hall of Fame Cisco Employee
SPA endpoints are supported
SPA endpoints are supported in the SMB community, you might want to move this over there.
java
if this helps, please rate
