01-06-2012 01:19 PM - edited 03-21-2019 05:09 AM
I recently upgraded from the 8.1 firware to the 8.2 firware on my UC540. The upgrade went smoothly and there were seemingly no issues until the next day I attempted to access my webvpn and found it no longer worked. I am using the anyconnect-dart-win-2.5.3055-k9.pkg and previous to the upgrade, everything was working fine. I have attempted to uninstall and reinstall the package, with no avail. Has anyone else had issues with the ssl vpn not working after the upgrade?
Solved! Go to Solution.
01-08-2012 05:54 PM
Hi Derek,
You may need to redo the Crypto, something in the back of my mind reminds of a similar issue another user on these forums had and I think that was the end result... I have been searching for it to show you the outcome but still cannot find it I think they must not have tagged it properly and market it as answered
Don't agonize on this problem too much, before calling support and getting them to assist you with it, check and make sure you do have the latest anyconnect package installed, the newer 8.2 SWP may require it, and make sure you do a full reload of the system when you do apply the newest anyconnect package as well.
But if you start to agonize on this issue, PLEASE call support and get them to help you, that is what they are there for after all
Cheers,
David.
01-08-2012 05:54 PM
Hi Derek,
Cheers,
David.
01-09-2012 05:34 PM
Thanks David, that was it. I had a suspicion that it was the problem, but I couldn't find an example of how to rebuild it. I found one searching google and all is now fixed, thanks!
01-09-2012 07:14 PM
EXCELLENT!!!
I'm so glad to hear it is all good now Derek
Cheers,
David.
