SSL VPN port number modify
billymobilizer
Is it possible to change SSL VPN port number from 443 to other ports such as 4443 on UC540 ? Will SPA525 remote phone still work after this change ?
The reason I need to change the default port is because 443 port was used by  the exchange server behind the UC.
Did anyone did  this before ?
bkwon
SPA525 phone work with 443 only by default, which means the port # is not configurable in the phone
bkwon
i just verified with end point team that changing the port is configurable in SPA525 phone, goto the VPN Server field in the phone, add ":4443" (new port number) to the end of server ip address.
example:
server-address:4443
yes, i got it working yesterday on UC540 by changing the port to 4443 too. Thanks for your help~
