I have a strange problem. We have a UC540 running 8.0.2 with SSL VPN enabled.
There is a 525G phone that connects remotely.
Every few days or so, the VPN stops working and phone does not connect. When I try to connect from a computer, it tries to establish the VPN connection and then eventually hangs or gives me a "AnyConnection was not able to establish a connection to the specified secure gateway. Please try connecting again." . When I reboot the box, VPN works again.
Will this be fixed by upgrading to 8.0.4 or 8.0.5? Anyone else having such an issue?
Without upgrading the software, is there a command I can use to reset the VPN so that it starts working again without the reboot?
Thanks!
