Static Routes
aaron.james
Quick question...
As the recommended and only way to configure the UC320 is to replace the internet router, how do I add static routes to the devices data vlan? as we have multiple internal ranges and a VPN for management and NAT, I need to add these IP subnet routes onto the device.
This seams like a very powerful product, but heavily restricted by what you can do with the interface. For a VoIP system, its great, but Cisco forcing us to use it as a router, where is that added functionality thats standard on all routers?
Hi Aaron,
There are several supported network topologies.  One of which is using a different router/firewall as the edge router of the network see:
http://www.cisco.com/web/partners/sell/smb/tools_and_resources/unified_communications_300.html   Adding a UC300 solution to an existing Small Business Network
Chris
