Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
755
Highlighted
Beginner
Strange Slow Ring Tones After Firmware Upgrade
I have just upgraded two UC320W's to firmware version 2.3.2(6) which seemed to go well.  However all the phones, SPA509G's and SPA504G's, ringtones changed.  At first I logged in to them all and changed the ringtone from "Retro" to "Classic -1" as I think this is what they were on before the upgrade, but there is a 6 second space between rings.  This may sound like a small issue but it makes the phones look broken, they basically ring onece then flash for six seconds before you hear another ring.
I did not see this listed in the known issues of the firmware but it has happend on the two systems I have upgraded.  Has anyone else seen this and how do I fix it?
Cheers,
Tony
Everyone's tags (4)
1 ACCEPTED SOLUTION
Highlighted
Enthusiast
Hi Tony,
Please send me an email at wenyang@cisco.com. I will reply you with a PMF to be installed in your system to correct the ring tone.
Best regards,
Wendy
4 REPLIES 4
Highlighted
Frequent Contributor
Hi Tony,
What 'Region' do you have configured on the two systems?  Please confirm which Ringtone(s) you are experiencing the delay.
Chris
Highlighted
Beginner
Hi Chris,
Region = United Kingdon
Dial Plan = Local calls are 7-Digits
We only use one ringtone "Classic-1"
Cheers,
Tony
Highlighted
Enthusiast
Hi Tony,
Best regards,
Wendy
Highlighted
Beginner
Hello Wendy,
I also had a call open with Cisco Support and they sent me cadence-1_fix.pmf which fixed the rin tone.  Incidently it also fixed the Du-dut ring tone that someone else used.
Thank you,
Tony
