03-07-2013 02:16 PM - edited 03-21-2019 07:04 AM
Edit to add: This is in regards to the UC320W with most recent firmware.
A timely question. In most of the USA the change to daylight savings time occurs at 2:00AM Sunday morning. At 2:00AM it will become 3:00AM DST. If "use daylight savings?" and "enable USB backup?" are checked and left at default values, and scheduled maintenance is left at it's default value, it is unclear if a problem will occur. The default time for a scheduled backup to a USB is 2:00 AM Sunday, and the default reboot time is 3:00AM Sunday. Do I need to change the scheduled times before this weekend? Or does it somehow work anyway? Thank You.
03-07-2013 02:31 PM
Hi Brian,
Please move the system backup time and reboot time to 3:00AM and 4:00AM, and apply configure to make them effective.
Best regards,
Wendy
03-07-2013 02:43 PM
Thank you for the prompt response. Just a suggestion to your developers. Perhaps in the future the default values for backup could be 3:15am, and 3:30am for reboot, with the minute values hard coded in the manner as they are currently at xx:00 xx. This would preclude event conflict. Thanks again.
