The rings and background images do not show up on my IP Phones (7970,7921,7961)
lukekrouse
I have tried and tried to follow previous instructions on the website but have had no such luck. I am still unable to get the rings and background images to display on my phones menu. I have performed a dir command and I see the images in the flash as well as the rings. However, they still do not show up on the phones. Any help would be great. I have attached my dir flash
Luke
26 Replies 26
Saurabh Verma
Level 4
Level 4
Hi Luke,
Can you capture the output of "debug tftp event" and "debug tftp packet" when you try to invoke either the ringer or the background image feature on the UC 500? Also, can you forward us a copy of the running configuration?
Saurabh
Saurabh,
I have turned on the debug events and below are the results of the debug. I haev also attached my running config.
EI-UC520-1#dir
Directory of flash:/
    1  -rw-    25471036  Aug 30 2007 21:32:24 -04:00  uc500-advipservicesk9-mz.124-11.XW
    2  -rw-     1702519  Aug 30 2007 21:37:18 -04:00  APPS-1.0.1.SBN
    3  -rw-     2544709  Aug 30 2007 21:37:28 -04:00  apps11.1-1-2-26.sbn
    4  -rw-     2351206  Aug 30 2007 21:37:34 -04:00  apps31.8-1-0-89.sbn
    5  -rw-     1706643  Aug 30 2007 21:37:40 -04:00  cmterm_7936.3-3-5-0.bin
    6  -rw-      420122  Aug 30 2007 21:37:42 -04:00  cnu11.3-1-2-26.sbn
    7  -rw-      415208  Aug 30 2007 21:37:44 -04:00  cnu31.8-1-0-89.sbn
    8  -rw-     1998336  Aug 30 2007 21:37:50 -04:00  cnu41.2-7-6-26.sbn
    9  -rw-     1979692  Aug 30 2007 21:37:56 -04:00  cnu70.2-7-6-26.sbn
   10  -rw-      331483  Aug 30 2007 21:37:58 -04:00  CP7902080001SCCP051117A.sbin
   11  -rw-         871  Aug 30 2007 21:38:00 -04:00  CP7921G-1.0.1.LOADS
   12  -rw-     2111057  Aug 30 2007 21:38:08 -04:00  cvm11sccp.8-0-2-25.sbn
   13  -rw-     2105538  Aug 30 2007 21:38:18 -04:00  cvm31sccp.8-1-0-90.sbn
   14  -rw-     1960127  Aug 30 2007 21:38:26 -04:00  CVM41.2-0-2-26.sbn
   15  -rw-     1994898  Aug 30 2007 21:38:36 -04:00  CVM70.2-0-2-26.sbn
   16  -rw-      392191  Aug 30 2007 21:38:38 -04:00  dsp11.1-1-2-26.sbn
   17  -rw-      277845  Aug 30 2007 21:38:38 -04:00  dsp31.8-1-0-89.sbn
   18  -rw-     1447362  Aug 30 2007 21:38:44 -04:00  GUI-1.0.1.SBN
   19  -rw-      174049  Aug 30 2007 21:38:44 -04:00  jar11sccp.8-0-2-25.sbn
   20  -rw-      307415  Aug 30 2007 21:38:46 -04:00  jar31sccp.8-1-0-90.sbn
   21  -rw-      707135  Aug 30 2007 21:38:48 -04:00  Jar41.2-9-2-26.sbn
   22  -rw-      866919  Aug 30 2007 21:38:52 -04:00  Jar70.2-9-2-26.sbn
   23  -rw-      129476  Aug 30 2007 21:38:54 -04:00  P0030702T023.bin
   24  -rw-         459  Aug 30 2007 21:38:54 -04:00  P0030702T023.loads
   25  -rw-      685334  Aug 30 2007 21:38:56 -04:00  P0030702T023.sb2
   26  -rw-      129880  Aug 30 2007 21:38:56 -04:00  P0030702T023.sbn
   27  -rw-       49169  Aug 30 2007 21:38:58 -04:00  S00104000100.sbn
   28  -rw-         656  Aug 30 2007 21:38:58 -04:00  SCCP11.8-0-3S.loads
   29  -rw-         644  Aug 30 2007 21:38:58 -04:00  SCCP31.8-1-1SR2S.loads
   30  -rw-     2078210  Aug 30 2007 21:39:06 -04:00  SYS-1.0.1.SBN
   31  -rw-         660  Aug 30 2007 21:39:06 -04:00  term06.default.loads
   32  -rw-         660  Aug 30 2007 21:39:06 -04:00  term11.default.loads
   33  -rw-         644  Aug 30 2007 21:39:06 -04:00  term31.default.loads
   34  -rw-         591  Aug 30 2007 21:39:08 -04:00  TERM41.7-0-3-0S.loads
   35  -rw-         591  Aug 30 2007 21:39:08 -04:00  term41.default.loads
   36  -rw-         591  Aug 30 2007 21:39:08 -04:00  term61.default.loads
   37  -rw-         591  Aug 30 2007 21:39:08 -04:00  TERM70.7-0-3-0S.loads
   38  -rw-         591  Aug 30 2007 21:39:08 -04:00  term70.default.loads
   39  -rw-         591  Aug 30 2007 21:39:10 -04:00  term71.default.loads
   40  -rw-      893001  Aug 30 2007 21:39:12 -04:00  TNUX-1.0.1.SBN
   41  -rw-     2196478  Aug 30 2007 21:39:20 -04:00  TNUXR-1.0.1.SBN
   42  -rw-     1296760  Aug 30 2007 21:39:24 -04:00  WLAN-1.0.1.SBN
   43  -rw-        4627  Aug 30 2007 21:39:32 -04:00  admin_user.html
   44  -rw-      653523  Aug 30 2007 21:39:34 -04:00  admin_user.js
   45  -rw-        8160  Aug 30 2007 21:39:34 -04:00  Analog1.raw
   46  -rw-        8160  Aug 30 2007 21:39:34 -04:00  Analog2.raw
   47  -rw-        5280  Aug 30 2007 21:39:36 -04:00  AreYouThere.raw
   48  -rw-        5040  Aug 30 2007 21:39:36 -04:00  AreYouThereF.raw
   49  -rw-        8160  Aug 30 2007 21:39:36 -04:00  Bass.raw
   50  -rw-       12240  Aug 30 2007 21:39:36 -04:00  CallBack.raw
   51  -rw-       16040  Aug 30 2007 21:39:38 -04:00  Chime.raw
   52  -rw-        1029  Aug 30 2007 21:39:38 -04:00  CiscoLogo.gif
   53  -rw-        8160  Aug 30 2007 21:39:38 -04:00  Classic1.raw
   54  -rw-       16080  Aug 30 2007 21:39:40 -04:00  Classic2.raw
   55  -rw-       10800  Aug 30 2007 21:39:40 -04:00  ClockShop.raw
   56  -rw-         618  Aug 30 2007 21:39:40 -04:00  CME_GUI_README.TXT
   57  -rw-         953  Aug 30 2007 21:39:40 -04:00  delete.gif
   58  -rw-         495  Aug 30 2007 21:39:40 -04:00  DistinctiveRingList.xml
   59  -rw-       16344  Aug 30 2007 21:39:42 -04:00  dom.js
   60  -rw-         864  Aug 30 2007 21:39:42 -04:00  downarrow.gif
   61  -rw-        9600  Aug 30 2007 21:39:42 -04:00  Drums1.raw
   62  -rw-       13440  Aug 30 2007 21:39:42 -04:00  Drums2.raw
   63  -rw-       75650  Aug 30 2007 21:39:44 -04:00  en_bacd_allagentsbusy.au
   64  -rw-       83291  Aug 30 2007 21:39:44 -04:00  en_bacd_disconnect.au
   65  -rw-       63055  Aug 30 2007 21:39:46 -04:00  en_bacd_enter_dest.au
   66  -rw-       37952  Aug 30 2007 21:39:46 -04:00  en_bacd_invalidoption.au
   67  -rw-      496521  Aug 30 2007 21:39:48 -04:00  en_bacd_music_on_hold.au
   68  -rw-      123446  Aug 30 2007 21:39:48 -04:00  en_bacd_options_menu.au
   69  -rw-       42978  Aug 30 2007 21:39:50 -04:00  en_bacd_welcome.au
   70  -rw-       34794  Aug 30 2007 21:39:50 -04:00  en_bacd_xferto_operator.au
   71  -rw-        6146  Aug 30 2007 21:39:50 -04:00  ephone_admin.html
   72  -rw-       15840  Aug 30 2007 21:39:50 -04:00  FilmScore.raw
   73  -rw-       16080  Aug 30 2007 21:39:52 -04:00  HarpSynth.raw
   74  -rw-        8160  Aug 30 2007 21:39:52 -04:00  Jamaica.raw
   75  -rw-       16080  Aug 30 2007 21:39:52 -04:00  KotoEffect.raw
   76  -rw-        4658  Aug 30 2007 21:39:52 -04:00  logohome.gif
   77  -rw-      496521  Aug 30 2007 21:39:56 -04:00  music-on-hold.au
   78  -rw-       12720  Aug 30 2007 21:39:56 -04:00  MusicBox.raw
   79  -rw-        3724  Aug 30 2007 21:39:56 -04:00  normal_user.html
   80  -rw-       79908  Aug 30 2007 21:39:58 -04:00  normal_user.js
   81  -rw-        8160  Aug 30 2007 21:39:58 -04:00  Piano1.raw
   82  -rw-       15360  Aug 30 2007 21:39:58 -04:00  Piano2.raw
   83  -rw-        1347  Aug 30 2007 21:39:58 -04:00  plus.gif
   84  -rw-        9360  Aug 30 2007 21:40:00 -04:00  Pop.raw
   85  -rw-        7200  Aug 30 2007 21:40:00 -04:00  Pulse1.raw
   86  -rw-        4000  Aug 30 2007 21:40:00 -04:00  Ring1.raw
   87  -rw-        4000  Aug 30 2007 21:40:00 -04:00  Ring2.raw
   88  -rw-        4000  Aug 30 2007 21:40:02 -04:00  Ring3.raw
   89  -rw-        4000  Aug 30 2007 21:40:02 -04:00  Ring4.raw
   90  -rw-        4000  Aug 30 2007 21:40:02 -04:00  Ring5.raw
   91  -rw-        4000  Aug 30 2007 21:40:02 -04:00  Ring6.raw
   92  -rw-        4000  Aug 30 2007 21:40:04 -04:00  Ring7.raw
   93  -rw-         495  Aug 30 2007 21:40:04 -04:00  RingList.xml
   94  -rw-       10800  Aug 30 2007 21:40:04 -04:00  Sax1.raw
   95  -rw-       14160  Aug 30 2007 21:40:06 -04:00  Sax2.raw
   96  -rw-         843  Aug 30 2007 21:40:06 -04:00  sxiconad.gif
   97  -rw-         174  Aug 30 2007 21:40:06 -04:00  tab.gif
   98  -rw-        2410  Aug 30 2007 21:40:06 -04:00  telephony_service.html
   99  -rw-         870  Aug 30 2007 21:40:06 -04:00  uparrow.gif
  100  -rw-       16080  Aug 30 2007 21:40:08 -04:00  Vibe.raw
  101  -rw-         660  Aug 30 2007 21:40:08 -04:00  vlan.dat
  102  -rw-        9968  Aug 30 2007 21:40:08 -04:00  xml-test.html
  103  -rw-        3412  Aug 30 2007 21:40:10 -04:00  xml.template
  104  -rw-       11909  Aug 30 2007 21:40:18 -04:00  UC520W-8U-4FXO-K9-factory-4.2.0.cfg
  105  drw-           0  Aug 14 2009 06:03:50 -04:00  FLASH
  161  drw-           0  Aug 14 2009 06:03:50 -04:00  autoattendant
  165  drw-           0  Aug 14 2009 06:03:50 -04:00  bacdprompts
  168  drw-           0  Aug 14 2009 06:03:48 -04:00  Desktops
  187  drw-           0  Aug 14 2009 06:04:08 -04:00  PHONES
EI-UC520-1#cd Desktops
EI-UC520-1#cd 320x212x12
EI-UC520-1#dir
Directory of flash:/Desktops/320x212x12/
  182  -rw-         651  Jul 28 2009 22:12:44 -04:00  List.xml
128184320 bytes total (20426752 bytes free)
EI-UC520-1#more List.xml
URL="flash:/Desktops/CiscoFountain.png"/>
URL="flash:/Desktops/NantucketFlowers.png"/>
URL="flash:/Desktops/CampusNight.png"/>
URL="flash:/Desktops/Fountain.png"/>
URL="flash:/Desktops/MorroRock.png"/>
URL="flash:/Desktops/CiscoLogo.png"/>
EI-UC520-1#un all
All possible debugging has been turned off
EI-UC520-1#term mon
EI-UC520-1#debug tftp events
TFTP Event debugging is on
EI-UC520-1#debug tftp packets
TFTP Packet debugging is on
EI-UC520-1#
Sep  3 20:14:38.760: TFTP: Server request for port 49198, socket_id 0x84D98F84 f              or process 165
Sep  3 20:14:38.760: TFTP: read request from host 10.1.1.15(49198) via BVI100
Sep  3 20:14:38.760: TFTP: Looking for Desktops/320x212x12/List.xml
Sep  3 20:14:38.760: TFTP: Sending error 1 No such file
Oh, looks like you are missing the tftp-server commands. Can you add the following CLIs?
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
If you still run into an issue, please capture the latest running config and the debug commands.
Saurabh
Maybe I am missing something again. How do you add those commands. I have tried to enter them as you have listed however I get the following errors. I have even tried to type enable prior.
uc520#tftp-server flash:/Desktops/CampusNight.png
% Invalid input detected at '^' marker.
uc520#enable
Luke
These commands must be entered in configuration mode. Please type "conf t" before typing them in.
Marcos
Here is the result of that step:
uc520#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
uc520(config)#tftp-server flash:/Desktops/CampusNight.png
Warning: flash:/Desktops/CampusNight.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/TN-CampusNight.png
Warning: flash:/Desktops/TN-CampusNight.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/CiscoFountain.png
Warning: flash:/Desktops/CiscoFountain.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/TN-CiscoFountain.png
Warning: flash:/Desktops/TN-CiscoFountain.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/CiscoLogo.png
Warning: flash:/Desktops/CiscoLogo.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/TN-CiscoLogo.png
Warning: flash:/Desktops/TN-CiscoLogo.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/Fountain.png
Warning: flash:/Desktops/Fountain.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/TN-Fountain.png
Warning: flash:/Desktops/TN-Fountain.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/MorroRock.png
Warning: flash:/Desktops/MorroRock.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/TN-MorroRock.png
Warning: flash:/Desktops/TN-MorroRock.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/NantucketFlowers.png
Warning: flash:/Desktops/NantucketFlowers.png does not exist.  Command retained.
uc520(config)#tftp-server flash:/Desktops/TN-NantucketFlowers.png
Warning: flash:/Desktops/TN-NantucketFlowers.png does not exist.  Command retained.
uc520(config)#tftp-server flash:Desktops/320x212x16/List.xml
uc520(config)#tftp-server flash:Desktops/320x212x12/List.xml
uc520(config)#tftp-server flash:Desktops/320x216x16/List.xml^Z
uc520#
Did I enter those Commands correctly?
Hi Luke,
You don't have the required files. These are bundled in the Software Pack, can you copy them to the flash?You can download the software pack from the page below - https://supportforums.cisco.com/docs/DOC-9829
Saurabh
Sorry to ask you this way!
Well i am also having the same problem regarding background customization. In my case ip phone 7975g is not downloading the image from cme 8.6. In the menu there are 3 options (1. defaulf and 2 and 3 added by me). In the flash:Desktops/320x216x16 all the files are there but its not downloading from cme.Here are the configurations
LIST.XML is as
URL="TFTP:Desktops/320x216x16/logo1.png"/>
URL="TFTP:Desktops/320x216x16/CampusNight.png"/>
and tftp binding is as
CME−CUE(config)#tftp−server flash:Desktops/320x216x16/TN−logo1.png
CME−CUE(config)#tftp−server flash:Desktops/320x216x16/logo1.png
CME−CUE(config)#tftp−server flash:Desktops/320x216x16/List.xml
CME−CUE(config)#tftp−server flash:Desktops/320x216x16/TN−CampusNight.png
CME−CUE(config)#tftp−server flash:Desktops/320x216x16/CampusNight.png
when i give debug tftp event and reset the phone nothing happened there, even in the ip phone background menu my added thumbnail is completely white. So guide me to solve this problem and also tell me do i need to upgrade firmware of ip phone?
thanks in advance
lukekrouse
Saurabh,
Am I able to use the CLI to do that? When I download UC520-7.0.3.zip and extract the files from the download where do I extract the files to? my desktop? Then do I use the copy tftp-server command? Can you provide a sample of how it would look.
You can extract the CME-Support-Files-7.0.3.tar to your desktop. Make sure that you are running a tftp server on your desktop. You can then execute the following CLI (in the exec mode):
archive tar /xtract tftp://192.168.10.11/CME-Support-Files-7.0.3.tar flash:
  where, 192.168.10.11 is the IP address of the tftp-server (your PC if you have tftp-server installed on your PC).
The above will install all the required background image and ringer files in the flash.
HTH,
Saurabh
Hi Luke,
Here is a brief way to do it:
Local Upload:
Download a TFTP program such as http://support.3com.com/software/3cdv2r10.zip
  1. Configure the TFTP section to point to the folder that has the files you want to have accessible to the system
  2. Upload the fiiles to the UC-500
  3. Check your TFTP-SERVER by doing the following command on the CLI "ROUTER# sh run | s tftp-serv" (Without the "") take note of what is there as they may need to be deleted and replaced with the correct ones.
    EXAMPLE OF WHAT IT SHOULD LOOK LIKE:
    tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
    tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
    tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
    tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
    tftp-server flash:/ringtones/RingList.xml alias RingList.xml
    tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
    tftp-server flash:/ringtones/Bass.raw alias Bass.raw
    tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
    tftp-server flash:/ringtones/Chime.raw alias Chime.raw
    tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
    tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
    tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
    tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
    tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
    tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
    tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
    tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
    tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
    tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
    tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
    tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
    tftp-server flash:/ringtones/Pop.raw alias Pop.raw
    tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
    tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
    tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
    tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
    tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
    tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
    tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
    tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
    tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
    tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
    tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
    tftp-server flash:/Desktops/320x212x16/List.xml
    tftp-server flash:/Desktops/320x212x12/List.xml
    tftp-server flash:/Desktops/320x216x16/List.xml
  4. To modify the the TFTP-SERVER on teh command line do the following commands "ROUTER# conf t" (Without the ""), you can copy and past the above assuming that you used CCA version 2.01 to provision the system, if not make sure that the file path matches exactly where the file is located otherwise it will bomb out on you and it wont work.
If it is from a remote location, you dont have many options unless you can use the Cisco VPN client and can VPN into the system, this way you act as though you are there locally infront of the system.
This should be fairly straight forward, make sure you use the files that are in the 7.0.3 or 7.1.1 file packs, they are the latest and are in a structured file format, some people just slap them directly on teh flash drive, but i can tell you that this is a BAD way to do it, its also lazy and it creates more problems then it is worth it.
Good Luck.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I did as I was instructed and I still am unable to see the rings and background images. "Rings Unavailable" or "Selections Unavailable". However I did notice in my attached running config that the files are now there in the flash.
Almost there I believe,
Luke
Hi Luke,
Can you capture the debugs again?
-Saurabh
Here are the debug events:
EI-UC520-1#un all
EI-UC520-1#term mon
EI-UC520-1#
Sep  4 12:51:18.516: TFTP: Server request for port 49159, socket_id 0x8618B5AC for process 165
Sep  4 12:51:18.516: TFTP: read request from host 10.1.1.11(49159) via BVI100
Sep  4 12:51:18.516: TFTP: Looking for Desktops/320x212x12/List.xml
Sep  4 12:51:18.516: TFTP: Sending error 1 No such file
