Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
363
Beginner
Tracking call origin
We have a UC560 with an AutoAttendant script answering all lines. In our AA script menu, pressing "1" rings Blast Group 1 and pressing "2" rings Blast Group 2.
Here is the layout of the Blast Groups:
Blast 1 = Extensions 21, 29, 30, 31
Blast 2 = Extensions 29, 30
How can the people at extensions 29 and 30 know which Blast Group was selected from the menu (different department of the company) and/or if someone dialed their extension directly? Currently, extension 29 and 30 all ring and display the same message whether someone dialed Blast1, Blast2 or their direct extension. We would like to be able to have a different ring or at least a different message on the call display.
I tried setting up a share extension as a 2nd button on those phones and using that extension instead of a Blast Group. That works fine, but when someone uses that line all calls go directly to voicemail without ringing on the other phones.
2 ACCEPTED SOLUTIONS
Beginner
I think you will have to use an overlay number on the phones to do this (Before blast group was possible this was the only solution to ringing multiple phones simultaneously)
Enthusiast
Hello Francis,
I would create a second normal lines on the phones, and then add the second line to the second blast group.
Hope this helps.
-john
3 REPLIES 3
Beginner
Enthusiast
Hello Francis,
Hope this helps.
-john
Beginner
Two excellent solutions! I decided to go with a second "normal" extension on the phones as it will be easier to manage later on if we add/remove extensions from the Blast Groups.
