Transfer calls between SPA525G2 phones
runar
Beginner
Beginner
Is it possible to transfer calls between 2 SPA525G2 phones internally in a office, not using the PBX-solution to do it?
Absolutely. Extension dialing is local and doesnt traverse the WAN. Transfer sofkeys can be used or you can put the same shared line on both phones and Hold - Resume between them as well.
Steve
Recognize Your Peers
