Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
686
SPA52GUser
Beginner
Transferring Calls Directly to Voicemail with SPA525G
We want to transfer calls directly to voicemail without having the call ring at the extension. Does anyone know of a workaround? Please advise if I should post this in another spot.
Thanks.
1 ACCEPTED SOLUTION
mdobiac
Participant
Hello SPA52GUser,
Depending on your phone system if you have the option of configuring a dial plan using a prefix then the extension user to send the call directly to VM for the call routing.
Example the UC500 series used the prefix 6 then the extension of the user to call/transfer directly to a users VM.
Hope this helps,
Michael D.
If this post is helpful please rate or mark as correct.
1 REPLY 1
mdobiac
Participant
Hello SPA52GUser,
Hope this helps,
Michael D.
