Trunk SIP between two UC-320W
claude.berthet
Would it be possible to establish a SIP trunk (or anything else) between 2 UC-320W located in two sites ?
Thanks for your replies....
fscharz
Hello Claude,
I am afraid this is not possible. Even if you can make one VOIP account register on both devices you will have issues with the inbound calls.
What is the reason for that setup?
Friedrich
Hello Friedrich,
We were looking for a simple solution to install 3 ip phones on the two sites of a customer, linked by a VPN. Our reseller provides us some UC-320W and SPA-502G, but it seems that this solution is not possible...
Will it works with two UC560 ? Or maybe is it a better solution ?
Claude
Hello Claude,
this will not be possible with the UC320W. UC560 with either SPA525G or SPA525G2 should cater for your setup with a remote VPN.
Friedrich
For your decision, keep in mind that both the UC320 and also the UC5x0 are announced EOS/EOL. But the (not EOL) CUCME (the Express-Version that runs on the router) can easily handle remote-phones.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
