UC 500 and Greenbow VPNClient
I'm trying to configure remote access via Greenbow vpn client to UC500.
Is it possible to configure via CCA or do I have to do it by cli?
- Via CLI,
We have a fixed value:
security ->VPN server, VPN Group EZVPN_GROUP_1.
- How can I configure VPN Group (EZVPN_GROUP_1 ) on Greenbow setup??
TIA
fRancisco
3 REPLIES 3
David Trad
Rising star
Rising star
Hi Francisco,
Why wouldn't you use the Cisco VPN client?? It is free and very robust and works exceptionally well with Cisco products
Is there any particular reason as to why you use Greenbow?
Within CCA you can create a PCF file which you then import into the Cisco VPN client and it is all setup for you already
http://www.cisco.com/en/US/products/sw/secursw/ps2308/index.html
Have a look at it and download it and also use CCA to create the PCF, life would be much more simpler for you
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hello David
Thanks for ypur reply.
simple answer to your question:
- Some guys at Comercial/Pre-sales dicided...
I "only" have to implement...
Regards.
FRancisco
Hi Francisco,
I do not know enough about Green Bow to help you I guess
I best leave it for someone who would have more experience with it then me, but in the mean time I will have a look into it and if I see I can assist you will re-port back
Cheers,
David.
