UC 500 questions
velocitystorm
I have a potential customer who is setting up a small helpdesk. I have questions along those lines.
With the UC500, can you setup escalations so that if someone has been onhold for a certain amount of time an alert can be sent or another line rung?
Is there a way to monitor queues?
Is there a way to generate reports for # of calls, who has received calls, time on the calls and so on?
Thanks!
Matt
Sure. Here ya go.
Ken
5 Replies 5
Brandon Buffin
Matt,
These functions are generally associated with call center software and are not built-in to the UC500. One option is to integrate the UC500 with Unified Contact Center Express. Take a look at the following link.
http://www.cisco.com/en/US/docs/video/cuva/2_0/english/adminstration/guide/vover.html
Hope this helps. If so, please rate the post.
Brandon
ttrentler
Level 4
Level 4
CallManager Express on the Uc500 has a Basic-ACD(B-ACD) service that does support queing and works in conjunction with huntgroups. While I do not know of a way to provide escalation with this product it does give limited Que and Agent stats.
Yes - The B-ACD functionality works great. I've attached the B-ACD configuration guide.
Thanks for posting this, but it expired. Can you post again or send to me directly?
Thanks!
Matt
Sure. Here ya go.
Ken
