UC 540 call forward to external destination
unpersonal
hello everybody
i've a urgent problem with a uc 540. i hope you can help me...
i'd like to forward calls from an internal shared extension (as example 25) to an external destination (as example my home phone).
if i call the (shared) extension (that is forwarded to my home phone) from another internal extension, the redirection works fine.
if i call the (shared) extension (that is forwarded to my home phone) from external (as example from my mobile (handy) phone), the redirection fails. i hear a busy tone (fast beeps like i'm busy).
if i test the same with a normal extension: equal result.
i tested the same with different forward methods (directly on the phone, on the uc 540 (extension), other extension types): equal result
it seems to be a problem with forward rights from external, but i can't find any options to configure such rights...
all other works fine.
we use bri and i configure the uc 540 with cisco configuration assistant.
the customer likes to redirect all calls after 20 sec to his external mobile phone.
does anyone have any idea? i searched already x hours without success and we should have a solution... :-(
definition of external (because of my ugly english): i mean a phone, which is located outside the uc 540 network (pstn)
this did not help:
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=225105528e1c46ad94c8cdc559804aa7_Enable_Call_Forwarding_to_Outside_Extension_on_UC500_series.xml
the prefix for the outgoing line is set.
thank you very much!
best regards
claude
try
interface bri01/0
isdn map address .  plan unknown type unknown
16 Replies 16
Hello Claude,
You may try using SNR(Single Number Reach) this feature can call the external number after few seconds as it is set if the extension is not answered.
HTH,
Alex
*Please rate helpful posts
Hey
thank you for reply!
i tried this already without success... unfortunately it behaves the same.
any other ideas? i really think that external forwarding is denied on the uc.
regards
claude
Take "debug isdn q931" with "term mon" for a failed, and for a succesful call.
sorry, i don't know what to do exactly. should i do this with ssh (terminal)? can you please describe the steps?
We ran into something similar with our setup.
What at the digits being dialed when you are trying to reach the outside number?  Specifically the first 3?
We did not use the default ext setup that came with the UC.  What was happening was the "default" ext's were still in the config file.  So when trying to transfer outside the first 3 digits matched an ext that was not there, giving us the fast busy signal.
If you have access to the CLI, or even in the CCA under hte troubleshoot section, take a look at the running config and see if you have a conflict in there.  We ended up changing our ext ranges to get around the problem.  I did not find this actual issue until later in the rollout.
Also with the "Single number reach" feature, once you configured it on the CCA, did you actually enable it on the phone?
vanmarcke
I had the same problem.
For me, setting the Caller ID to Any Number and setting the Caller ID number solved it!
Peter
Hello
Unfortunately no change... I set the setting like you (also before).
Paolo, could you explain your suggestion?
Does anyone have another idea? I’m sure it can’t be that difficult!
claude
I recommend you have this worked on by a reputable consultant or UC certified Cisco partner.
The product is not as easy it may seems to you and it is not designed to be configured by the end user.
hey
we are not end users. and i think there must be a solution for this little problem. actually this is a test project.
please any suggestions?
best regards
claude
I have indicated to you above already the steps to take. If you do not know how to do that, get someone experienced with configuring and administering Cisco routers.
hello
i debuged the line and in the log file i can read: invalid number (28)
but the number is correct set! i also used the access code.
after some other debuging i generated this log file:
i replaced the numbers in this logfile:
incoming number: source number, the number witch was used to call the customer
customer number: main number of uc540
forwarding destination: the number, witch is used as forwarding destination (as example my cell phone)
Internal_Extension_That_Should_Be_Forwarded: the number, that should be forwarded to my cell phone
-----------------------------------------------------------------------------START-----------------------------------------------------------------------------
--------------------------show logging--------------------------
Syslog logging: enabled (0 messages dropped, 7 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 1323 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 1922 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (1000000 bytes):
003732: Jul 25 12:55:13.340: %SYS-5-CONFIG_I: Configured from console by sysadminacc on vty1 (192.168.30.2)
003733: Jul 25 14:55:26.880: ISDN BR0/1/0 Q921: User RX <- UI sapi=0 tei=127
003734: Jul 25 14:55:26.880: ISDN BR0/1/0 Q931: SETUP pd = 8  callref = 0x62
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x0181, '[Incoming_Number]'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xC1, '[Internal_Extension_That_Should_Be_Forwarded]'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
003735: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=[Incoming_Number], Called Number=[Internal_Extension_That_Should_Be_Forwarded], Voice-Interface=0x8869A614,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
003736: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3001
003737: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
003738: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=[Incoming_Number], Called Number=[Internal_Extension_That_Should_Be_Forwarded], Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
003739: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
003740: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
003741: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 5
003742: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=[Internal_Extension_That_Should_Be_Forwarded] matchPattern=[Internal_Extension_That_Should_Be_Forwarded] replacePattern=21 replaced pattern=21
003743: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
003744: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
003745: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=21, Peer Info Type=DIALPEER_INFO_SPEECH
003746: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=21
003747: Jul 25 14:55:26.884: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
003748: Jul 25 14:55:26.888: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003749: Jul 25 14:55:26.888: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20005
003750: Jul 25 14:55:26.888: //-1/4FE2E67381E1/VTSP:(0/1/0):-1:-1:-1/vtsp_do_normal_call_setup_ind:
   IC State Machine (ICSM) Added
003751: Jul 25 14:55:26.888: //-1/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_create: .
003752: Jul 25 14:55:26.888: //-1/4FE2E67381E1/DSM:(0/1/0):-1/set_echo_canceller_data: echo_cancel: 1
003753: Jul 25 14:55:26.888: //-1/4FE2E67381E1/DSM:(0/1/0):-1/set_echo_canceller_data: echo_flags: 55, echo_len: 1024
003754: Jul 25 14:55:26.888: //-1/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_set_dsp_allocated: .
003755: Jul 25 14:55:26.892: //-1/4FE2E67381E1/DSM:(0/1/0):-1/dsmp_dsmapi_reserve_resource_cb: .
003756: Jul 25 14:55:26.892: //-1/4FE2E67381E1/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=[Incoming_Number]
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=[Internal_Extension_That_Should_Be_Forwarded]
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
003757: Jul 25 14:55:26.892: //-1/4FE2E67381E1/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x8869A614, Call Info(
   Calling Number=[Incoming_Number],(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=[Internal_Extension_That_Should_Be_Forwarded](TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=ALL_BRI, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
003758: Jul 25 14:55:26.892: //-1/4FE2E67381E1/CCAPI/ccCheckClipClir:
   In: Calling Number=[Incoming_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
003759: Jul 25 14:55:26.892: //-1/4FE2E67381E1/CCAPI/ccCheckClipClir:
   Out: Calling Number=[Incoming_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
003760: Jul 25 14:55:26.892: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003761: Jul 25 14:55:26.892: :cc_get_feature_vsa malloc success
003762: Jul 25 14:55:26.892: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003763: Jul 25 14:55:26.892:  cc_get_feature_vsa count is 3
003764: Jul 25 14:55:26.892: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003765: Jul 25 14:55:26.892: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308732720,feature_id:3877
003766: Jul 25 14:55:26.892: //2396/4FE2E67381E1/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=[Incoming_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=[Internal_Extension_That_Should_Be_Forwarded](TON=Subscriber, NPI=ISDN))
003767: Jul 25 14:55:26.892: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_set_elog_enable: .
003768: Jul 25 14:55:26.892: //-1/4FE2E67381E1/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x89AE443C; count=1
003769: Jul 25 14:55:26.892: //-1/4FE2E67381E1/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x894104E4
003770: Jul 25 14:55:26.892: //2396/4FE2E67381E1/VTSP:(0/1/0):-1:1:2/vtsp_indicate_call:
003771: Jul 25 14:55:26.896: //2396/4FE2E67381E1/CCAPI/cc_process_call_setup_ind:
   Event=0x8862CDA0
003772: Jul 25 14:55:26.896: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=[Internal_Extension_That_Should_Be_Forwarded], Peer Info Type=DIALPEER_INFO_SPEECH
003773: Jul 25 14:55:26.896: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=[Internal_Extension_That_Should_Be_Forwarded]
003774: Jul 25 14:55:26.896: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003775: Jul 25 14:55:26.896: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=[Internal_Extension_That_Should_Be_Forwarded], saf_enabled=0, saf_dndb_lookup=1, dp_result=0
003776: Jul 25 14:55:26.896: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20006
003777: Jul 25 14:55:26.896: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number [Internal_Extension_That_Should_Be_Forwarded]
003778: Jul 25 14:55:26.896: //2396/4FE2E67381E1/CCAPI/ccCallSetContext:
   Context=0x899DFF54
003779: Jul 25 14:55:26.896: //2396/4FE2E67381E1/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2396 with tag 3001 to app "_ManagedAppProcess_Default"
003780: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x89AE443C; count=1
003781: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: number=[Incoming_Number] type=unknown plan=isdn numbertype=calling
003782: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 3265
003783: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 3265
003784: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/sed_subst: Successful substitution; pattern=[Incoming_Number] matchPattern=(^..........$) replacePattern=0\1 replaced pattern=0[Incoming_Number]
003785: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
003786: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
003787: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: xlt_number=0[Incoming_Number] xlt_type=unknown xlt_plan=isdn
003788: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: number= type=UNKNOWN plan=UNKNOWN numbertype=redirect-called
003789: Jul 25 14:55:26.896: //-1/4FE2E67381E1/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
003790: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
003791: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: No match: number= type=UNKNOWN plan=UNKNOWN
003792: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: number=[Internal_Extension_That_Should_Be_Forwarded] type=subscriber plan=isdn numbertype=called
003793: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 5
003794: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 5
003795: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/sed_subst: Successful substitution; pattern=[Internal_Extension_That_Should_Be_Forwarded] matchPattern=[Internal_Extension_That_Should_Be_Forwarded] replacePattern=21 replaced pattern=21
003796: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
003797: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
003798: Jul 25 14:55:26.900: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: xlt_number=21 xlt_type=subscriber xlt_plan=isdn
003799: Jul 25 14:55:26.900: //2396/4FE2E67381E1/CCAPI/ccCallProceeding:
003800: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003801: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003802: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003803: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchSafModulePlugin:
   dialstring=21, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
003804: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003805: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003806: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003807: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003808: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchSafModulePlugin:
003809: Jul 25 14:55:26.900: //-1/4FE2E67381E1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003810: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=21, Called Number=21, Peer Info Type=DIALPEER_INFO_SPEECH
003811: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003812: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003813: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003814: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003815: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=21, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
003816: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
003817: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003818: Jul 25 14:55:26.900: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
003819: Jul 25 14:55:26.904: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
003820: Jul 25 14:55:26.904: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003821: Jul 25 14:55:26.904: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003822: Jul 25 14:55:26.904: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003823: Jul 25 14:55:26.904: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003824: Jul 25 14:55:26.904: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003825: Jul 25 14:55:26.904: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003826: Jul 25 14:55:26.904: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003827: Jul 25 14:55:26.904: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003828: Jul 25 14:55:26.904: //-1/4FE2E67381E1/DPM/dpMatchPeersCore:
003829: Jul 25 14:55:26.904: //-1/4FE2E67381E1/DPM/dpMatchSafModulePlugin:
   dialstring=21, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
003830: Jul 25 14:55:26.904: //-1/4FE2E67381E1/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003831: Jul 25 14:55:26.904: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20005, Params=0x899E1464, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
003832: Jul 25 14:55:26.904: //-1/4FE2E67381E1/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
003833: Jul 25 14:55:26.904: //-1/4FE2E67381E1/RXRULE/regxrule_vp_translate: calling_number=0[Incoming_Number] calling_octet=0x1
called_number=21 called_octet=0xC1
redirect_number= redirect_type=4294967295 redirect_plan=4294967295
003834: Jul 25 14:55:26.904: //2396/4FE2E67381E1/CCAPI/ccCheckClipClir:
   In: Calling Number=0[Incoming_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
003835: Jul 25 14:55:26.908: //2396/4FE2E67381E1/CCAPI/ccCheckClipClir:
   Out: Calling Number=0[Incoming_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
003836: Jul 25 14:55:26.908: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Destination Pattern=21$, Called Number=21, Digit Strip=TRUE
003837: Jul 25 14:55:26.908: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Calling Number=0[Incoming_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=21(TON=Subscriber, NPI=ISDN),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=4FE2E673-F460-11E2-81E1-ACF2C59E4440, Outgoing Dial-peer=20005
003838: Jul 25 14:55:26.908: //2396/4FE2E67381E1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=0[Incoming_Number]
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=21
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
003839: Jul 25 14:55:26.908: //2396/4FE2E67381E1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x8971AFBC, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=0[Incoming_Number],(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=21(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20005, Call Count On=FALSE,
   Source Trkgrp Route Label=ALL_BRI, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
003840: Jul 25 14:55:26.908: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003841: Jul 25 14:55:26.908: :cc_get_feature_vsa malloc success
003842: Jul 25 14:55:26.908: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003843: Jul 25 14:55:26.908:  cc_get_feature_vsa count is 4
003844: Jul 25 14:55:26.908: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003845: Jul 25 14:55:26.908: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308735632,feature_id:3878
003846: Jul 25 14:55:26.908: //2396/4FE2E67381E1/VTSP:(0/1/0):-1:1:2/vtsp_spi_event_handler:
   Event Category=1, Event=176
003847: Jul 25 14:55:26.908: //2397/4FE2E67381E1/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
003848: Jul 25 14:55:26.908: //2397/4FE2E67381E1/CCAPI/ccCallSetContext:
   Context=0x899E1414
003849: Jul 25 14:55:26.908: //2396/4FE2E67381E1/CCAPI/ccSaveDialpeerTag:
003850: Jul 25 14:55:26.908: htsp_timer_stop3
003851: Jul 25 14:55:26.908: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_create: .
003852: Jul 25 14:55:26.908: //2397/4FE2E67381E1/DSM:(50/0/297):-1/set_echo_canceller_data: echo_cancel: 1
003853: Jul 25 14:55:26.908: //2397/4FE2E67381E1/DSM:(50/0/297):-1/set_echo_canceller_data: echo_flags: 23, echo_len: 64
003854: Jul 25 14:55:26.908: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_set_dsp_allocated: .
003855: Jul 25 14:55:26.912: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsmp_dsmapi_reserve_resource_cb: .
003856: Jul 25 14:55:26.912: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_set_elog_enable: .
003857: Jul 25 14:55:26.912: //2397/4FE2E67381E1/VTSP:(50/0/297):-1:0:2369/vtsp_create_call_active_on_setup_req:
   Target Carrier ID=
003858: Jul 25 14:55:26.912: //2397/4FE2E67381E1/VTSP:(50/0/297):-1:0:2369/vtsp_create_call_active_on_setup_req:
   Source Trkgrp Route Label=ALL_BRIhtsp_setup_req
003859: Jul 25 14:55:26.912: //2397/4FE2E67381E1/CCAPI/cc_api_update_call_info:
   Interface=0x8971AFBC, Call Id=0x95D
003860: Jul 25 14:55:26.912: //2397/4FE2E67381E1/DSPAPI/[]/dsp_get_multimedia_capabilities:
003861: Jul 25 14:55:26.912: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_implement_feature:
003862: Jul 25 14:55:26.912: dsp_stream_mgr_implement_feature: feature id = 6
003863: Jul 25 14:55:26.912: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_implement_feature: Illegal callerid parameters, callerid_params = 0x0
003864: Jul 25 14:55:26.912: htsp_process_event: [50/0/297.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
003865: Jul 25 14:55:26.916: htsp_ephone_start_caller_id_tx calling num=0[Incoming_Number] calling name = called num=21 orig called num=
003866: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0[Incoming_Number], Peer Info Type=DIALPEER_INFO_SPEECH
003867: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=0[Incoming_Number]
003868: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003869: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=0[Incoming_Number], saf_enabled=0, saf_dndb_lookup=1, dp_result=0
003870: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=123
     2: Dial-peer Tag=83
003871: Jul 25 14:55:26.916: [50/0/297.1] set signal state = 0x0 timestamp = 0
003872: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003873: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003874: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003875: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003876: Jul 25 14:55:26.916: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003877: Jul 25 14:55:26.916: efxs_onhook_setup: local target is available
htsp_alert
003878: Jul 25 14:55:26.916: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_reinit_platform_info: .
003879: Jul 25 14:55:26.916: //2397/4FE2E67381E1/CCAPI/cc_api_call_proceeding:
   Interface=0x8971AFBC, Progress Indication=NULL(0)
003880: Jul 25 14:55:26.924: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsmp_dsmapi_reserve_resource_cb: .
003881: Jul 25 14:55:26.924: //2397/4FE2E67381E1/CCAPI/cc_api_call_alert:
   Interface=0x8971AFBC, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
003882: Jul 25 14:55:26.924: //2397/4FE2E67381E1/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
003883: Jul 25 14:55:26.924: ISDN BR0/1/0 Q921: L2_EstablishDataLink: sending SABME
003884: Jul 25 14:55:26.924: ISDN BR0/1/0 Q921: User TX -> SABMEp sapi=0 tei=75
003885: Jul 25 14:55:26.928: //2396/4FE2E67381E1/CCAPI/ccCallAlert:
003886: Jul 25 14:55:26.928: //2396/4FE2E67381E1/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
003887: Jul 25 14:55:26.928: //2396/4FE2E67381E1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=2396
003888: Jul 25 14:55:26.928: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_play_tone_control: Tone Ring Back generated in direction Network
003889: Jul 25 14:55:26.928: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_dsp_cp_dual_tone_on: cpPtr->off_time_third: 0, sl_delay: 0
003890: Jul 25 14:55:26.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003891: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003892: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003893: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003894: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
003895: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003896: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003897: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003898: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003899: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=83
     2: Dial-peer Tag=123
003900: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003901: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003902: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003903: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003904: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=83
003905: Jul 25 14:55:26.932: //2397/4FE2E67381E1/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2397
003906: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003907: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003908: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003909: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003910: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     2: Dial-peer Tag=83
003911: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003912: Jul 25 14:55:26.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003913: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003914: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003915: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
003916: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003917: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003918: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003919: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003920: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003921: Jul 25 14:55:26.936: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_pak_control: on = 0
003922: Jul 25 14:55:26.936: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_play_tone_control: Tone Ring Back generated in direction Network
003923: Jul 25 14:55:26.936: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_dsp_cp_dual_tone_on: cpPtr->off_time_third: 0, sl_delay: 0htsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 0
003924: Jul 25 14:55:26.936: htsp_process_event: [50/0/297.1, EFXS_WAIT_OFFHOOK, E_HTSP_CALLERID_WAITING]
003925: Jul 25 14:55:26.936: efxs_callerid_update
003926: Jul 25 14:55:26.936: efxs_callerid_update process caller_id_string
003927: Jul 25 14:55:26.936: efxs_callerid_update process caller_id_string OK
003928: Jul 25 14:55:26.936: efxs_callerid_update number= [0[Incoming_Number]] name= []
003929: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003930: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003931: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003932: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003933: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=83
003934: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003935: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003936: Jul 25 14:55:26.936: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003937: Jul 25 14:55:26.940: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003938: Jul 25 14:55:26.940: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003939: Jul 25 14:55:26.940: ISDN BR0/1/0 Q921: User RX <- UAf sapi=0 tei=75
003940: Jul 25 14:55:26.940: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_init:
003941: Jul 25 14:55:26.940: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_open_service:
    G711_U (5)
003942: Jul 25 14:55:26.940: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_voice_config_params:
003943: Jul 25 14:55:26.940:     6 parameters
    [0] ENCAP RTP: Tx SSRC=0, Rx SSRC=0, Tx VPXCC=0, Rx VPXCC=0
    IFP payload type=122, SID support=1, TSE payload=101, Sequence number start=0
    Redundancy=0, ClearChannel payload type=0, Fax payload type=0
    Alaw PCM switchover=0, MuLAW PCM switchover=0
    DTMF payload type=0, NTE receive payload type=101
    LMR tone payload type=0, NTE tone payload type=0
    Dynamic payload=255, Codec=g711ulaw
    [1] PO_JITTER: mode=2 initial=60(ms) max=1000(ms) min=40(ms) fax_nom=300(ms)
    [2] INFO_FIELD_SIZE: 160 bytes
    [3] IDLE_CODE_DET: Enable=0, Code=0x0, Duration=6000(ms)
    [4] ECHO_CANCEL: Flags=0x37, Echo length=128(ms)
    [5] CNG: 1
003944: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_config_params:
    3 parameters
003945: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_start_service:
    G711_U (5)
003946: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_call_progress_detect:
003947: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_voice_config_params:
003948: Jul 25 14:55:26.944:     5 parameters
    [0] ECHO_CANCEL: Flags=0x37, Echo length=128(ms)
    [1] GAIN: Input=0.0(dB), Output=0.0(dB)
    [2] AGC CONTROL: Input=off, Output=off
    [3] DIGIT_RELAY: 2
    [4] VAD: Enable=0, Threshold=-38(dBm)
003949: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_voice_config_params:
003950: Jul 25 14:55:26.944:     1 parameter
    [0] PAK_SUPPRESS: 1
003951: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_tone_on:
    Tone ID=1, Direction=1, Num frequencies=1
    Frequency(hz): a=425 b=0, Amplitude(dB): a=-10.0 b=0.0
    Cadence1(ms): ON=1000 OFF=4000
    Cadence2(ms): ON=0 OFF=0
    Cadence3(ms): ON=0 OFF=0
    Cadence4(ms): ON=0 OFF=0
    Frequency(hz): a2=33159 b2=63860 a3=34079 b3=23148 a4=35201 b4=49536
    ITO option group: 1
003952: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_tone_off:
003953: Jul 25 14:55:26.944: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_tone_on:
    Frequency(hz): a2=33159 b2=63860 a3=33792 b3=46636 a4=33040 b4=18088
    ITO option group: 1
003954: Jul 25 14:55:26.948: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=0 nr=0
003955: Jul 25 14:55:26.948: ISDN BR0/1/0 Q931: CALL_PROC pd = 8  callref = 0xE2
Channel ID i = 0x89
Exclusive, B1
003956: Jul 25 14:55:26.964: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=1
003957: Jul 25 14:55:26.964: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=1 nr=0
003958: Jul 25 14:55:26.964: ISDN BR0/1/0 Q931: ALERTING pd = 8  callref = 0xE2
Progress Ind i = 0x8188 - In-band info or appropriate now available
003959: Jul 25 14:55:26.984: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=2
003960: Jul 25 14:55:29.924: //2397/4FE2E67381E1/VTSP:(50/0/297):-1:0:2369/vtsp_cc_call_disconnected:
   Cause Value=19
003961: Jul 25 14:55:29.924: //2397/4FE2E67381E1/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x8971AFBC, Call Id=2397
003962: Jul 25 14:55:29.924: //2397/4FE2E67381E1/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
003963: Jul 25 14:55:29.924: //2396/4FE2E67381E1/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
003964: Jul 25 14:55:29.924: //2397/4FE2E67381E1/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
003965: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=21
003966: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003967: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003968: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003969: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003970: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003971: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0[Forwarding_Destination], Peer Info Type=DIALPEER_INFO_SPEECH
003972: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=0[Forwarding_Destination]
003973: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003974: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=0[Forwarding_Destination], saf_enabled=0, saf_dndb_lookup=1, dp_result=0
003975: Jul 25 14:55:29.924: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=124
     2: Dial-peer Tag=93
003976: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=21, Called Number=21, Calling Number=0[Incoming_Number], Calling DN=-1 Calling Id=2396,
   Redirect Number=0[Forwarding_Destination], Redirect Reason=2
003977: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003978: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003979: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003980: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003981: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=83
003982: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003983: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003984: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003985: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003986: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=93
     2: Dial-peer Tag=124
003987: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003988: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003989: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003990: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003991: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=93
003992: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
003993: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003994: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003995: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
003996: Jul 25 14:55:29.928: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
003997: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
003998: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003999: Jul 25 14:55:29.932: :cc_get_feature_vsa malloc success
004000: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004001: Jul 25 14:55:29.932:  cc_get_feature_vsa count is 5
004002: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004003: Jul 25 14:55:29.932: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308736304,feature_id:3879
004004: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004005: Jul 25 14:55:29.932:  feature_vsa is 899C7728,featname is 0
004006: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004007: Jul 25 14:55:29.932: :cc_get_feature_vsa malloc success
004008: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004009: Jul 25 14:55:29.932:  cc_get_feature_vsa count is 6
004010: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004011: Jul 25 14:55:29.932: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308734960,feature_id:3880
004012: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004013: Jul 25 14:55:29.932: : Generating new featurevsa,inserting it
004014: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004015: Jul 25 14:55:29.932:  feature call forward featname is 3
004016: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004017: Jul 25 14:55:29.932:  feature_vsa is 899C8288,featname is 0
004018: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004019: Jul 25 14:55:29.932: :cc_get_feature_vsa malloc success
004020: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004021: Jul 25 14:55:29.932:  cc_get_feature_vsa count is 7
004022: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004023: Jul 25 14:55:29.932: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308733616,feature_id:3881
004024: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004025: Jul 25 14:55:29.932: : Generating new featurevsa,inserting it
004026: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004027: Jul 25 14:55:29.932:  feature call forward featname is 3
004028: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004029: Jul 25 14:55:29.932: :cc_free_feature_vsa freeing 899C8528
004030: Jul 25 14:55:29.932: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004031: Jul 25 14:55:29.932:  vsacount in free is 6
004032: Jul 25 14:55:29.932: //2396/4FE2E67381E1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
004033: Jul 25 14:55:29.932: //2397/4FE2E67381E1/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
004034: Jul 25 14:55:29.932: //2397/4FE2E67381E1/CCAPI/ccCallDisconnect:
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
004035: Jul 25 14:55:29.932: //2397/4FE2E67381E1/CCAPI/cc_api_get_transfer_info:
004036: Jul 25 14:55:29.932: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_get_levels_sync: .
004037: Jul 25 14:55:29.936: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_initiate_close: .
004038: Jul 25 14:55:29.936: htsp_timer_stop3
004039: Jul 25 14:55:29.936: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_tone_off:
004040: Jul 25 14:55:29.936: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsmp_dsmapi_stats_cb: .
004041: Jul 25 14:55:29.936: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsmp_dsmapi_stats_cb: .
004042: Jul 25 14:55:29.936: htsp_process_event: [50/0/297.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
004043: Jul 25 14:55:29.936: [50/0/297.1] set signal state = 0x4 timestamp = 0
004044: Jul 25 14:55:29.940: //2397/4FE2E67381E1/VTSP:(50/0/297):-1:0:2369/vtsp_do_call_history:
   Coder Rate=-1
004045: Jul 25 14:55:29.940: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsp_stream_mgr_destroy: .
004046: Jul 25 14:55:29.940: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsm_delete_all_streams: .
004047: Jul 25 14:55:29.940: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsmapi_accept_modem_passthrough_session:  : dmgr: 86698CE0, active sessions 0, max sessions: 16 rejected sessions till now: 0
004048: Jul 25 14:55:29.944: //2397/4FE2E67381E1/DSM:(50/0/297):-1/dsmp_dsmapi_reserve_resource_cb: .
004049: Jul 25 14:55:29.944: //2397/4FE2E67381E1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8971AFBC, Tag=0x0, Call Id=2397,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
004050: Jul 25 14:55:29.944: //-1/4FE2E67381E1/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
004051: Jul 25 14:55:29.944: //2397/4FE2E67381E1/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
004052: Jul 25 14:55:29.944: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004053: Jul 25 14:55:29.944: :cc_free_feature_vsa freeing 899C7AA8
004054: Jul 25 14:55:29.944: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004055: Jul 25 14:55:29.944:  vsacount in free is 5
004056: Jul 25 14:55:29.944: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004057: Jul 25 14:55:29.944:  vsacount in free is 4
004058: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004059: Jul 25 14:55:29.948: :cc_get_feature_vsa malloc success
004060: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004061: Jul 25 14:55:29.948:  cc_get_feature_vsa count is 5
004062: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004063: Jul 25 14:55:29.948: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308735632,feature_id:3882
004064: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004065: Jul 25 14:55:29.948:  feature call forward featname is 3
004066: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004067: Jul 25 14:55:29.948: :cc_free_feature_vsa freeing 899C8288
004068: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004069: Jul 25 14:55:29.948:  vsacount in free is 4
004070: Jul 25 14:55:29.948: //2396/4FE2E67381E1/CCAPI/ccGetTBCTCap:
   TGRM TBCT Enabled; TBCT Capability=0
004071: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
004072: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
004073: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
004074: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
004075: Jul 25 14:55:29.948: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=83
004076: Jul 25 14:55:29.948: //2396/4FE2E67381E1/CCAPI/ccGetTBCTCap:
004077: Jul 25 14:55:29.952: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=0[Forwarding_Destination], Called Number=, Voice-Interface=0x0,
004078: Jul 25 14:55:29.952: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
004079: Jul 25 14:55:29.952: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
004080: Jul 25 14:55:29.952: //-1/51B70A649BE7/DPM/dpMatchPeersCore:
004081: Jul 25 14:55:29.952: //-1/51B70A649BE7/DPM/dpMatchPeersCore:
004082: Jul 25 14:55:29.952: //-1/51B70A649BE7/DPM/dpMatchPeersCore:
004083: Jul 25 14:55:29.952: //-1/51B70A649BE7/DPM/dpMatchSafModulePlugin:
   dialstring=0[Forwarding_Destination], saf_enabled=1, saf_dndb_lookup=1, dp_result=0
004084: Jul 25 14:55:29.952: //-1/51B70A649BE7/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     2: Dial-peer Tag=93
004085: Jul 25 14:55:29.952: //-1/51B70A649BE7/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
004086: Jul 25 14:55:29.952: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: number=0[Incoming_Number] type=unknown plan=isdn numbertype=calling
004087: Jul 25 14:55:29.952: //-1/51B70A649BE7/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
004088: Jul 25 14:55:29.952: //-1/51B70A649BE7/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
004089: Jul 25 14:55:29.952: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: No match: number=0[Incoming_Number] type=unknown plan=isdn
004090: Jul 25 14:55:29.952: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: number=0[Forwarding_Destination] type=subscriber plan=isdn numbertype=called
004091: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1112
004092: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 1112
004093: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/sed_subst: Successful substitution; pattern=0[Forwarding_Destination] matchPattern=^0 replacePattern= replaced pattern=[Forwarding_Destination]
004094: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
004095: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
004096: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: xlt_number=[Forwarding_Destination] xlt_type=subscriber xlt_plan=isdn
004097: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: number= type=subscriber plan=isdn numbertype=redirect-target
004098: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
004099: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-target number not found
004100: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: No match: number= type=subscriber plan=isdn
004101: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: number=21 type=unknown plan=unknown numbertype=redirect-called
004102: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
004103: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
004104: Jul 25 14:55:29.956: //-1/51B70A649BE7/RXRULE/regxrule_profile_translate_internal: No match: number=21 type=unknown plan=unknown
004105: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=124, Params=0x899DD624, Progress Indication=NULL(0)
004106: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/cc_fill_tg_params:
   Not a cic call
004107: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x89AE443C; count=2
004108: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_get_profile_from_trunkgroup_internal: Found profile PROFILE_ALL_BRI defined on trunk group
004109: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: number=0[Incoming_Number] type=unknown plan=isdn numbertype=calling
004110: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 6
004111: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 6
004112: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/sed_subst: Successful substitution; pattern=0[Incoming_Number] matchPattern=^.*$ replacePattern=[Customer_Main_Number] replaced pattern=[Customer_Main_Number]
004113: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
004114: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
004115: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: xlt_number=[Customer_Main_Number] xlt_type=unknown xlt_plan=isdn
004116: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: number=[Forwarding_Destination] type=subscriber plan=isdn numbertype=called
004117: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
004118: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
004119: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: No match: number=[Forwarding_Destination] type=subscriber plan=isdn
004120: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: number=21 type=unknown plan=unknown numbertype=redirect-called
004121: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
004122: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
004123: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_profile_translate_internal: No match: number=21 type=unknown plan=unknown
004124: Jul 25 14:55:29.956: //-1/4FE2E67381E1/RXRULE/regxrule_tg_translate: calling_number=[Customer_Main_Number] calling_octet=0x1
called_number=[Forwarding_Destination] called_octet=0xC1
redirect_number=21 redirect_type=0 redirect_plan=0
004125: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Trunk Group Select Interface Success;
   Interface=0x8869A614, Selected Interface=2, Selected DSL=2
004126: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/ccCheckClipClir:
   In: Calling Number=[Customer_Main_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
004127: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/ccCheckClipClir:
   Out: Calling Number=[Customer_Main_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
004128: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Destination Pattern=007[46789]......., Called Number=[Forwarding_Destination], Digit Strip=TRUE
004129: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Calling Number=[Customer_Main_Number](TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=[Forwarding_Destination](TON=Subscriber, NPI=ISDN),
   Redirect Number=21, Display Info=
   Guid=51B70A64-F460-11E2-9BE7-AFDEE4C60810, Outgoing Dial-peer=124
004130: Jul 25 14:55:29.956: //2396/4FE2E67381E1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=[Customer_Main_Number]
   cisco-anitype=0
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=[Forwarding_Destination]
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=73
   cisco-rdn=21
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=2   fwd_final_type =0
004131: Jul 25 14:55:29.960: //2396/4FE2E67381E1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x8869A614, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=[Customer_Main_Number],(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=[Forwarding_Destination](TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=124, Call Count On=FALSE,
   Source Trkgrp Route Label=ALL_BRI, Target Trkgrp Route Label=ALL_BRI, tg_label_flag=2, Application Call Id=)
004132: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004133: Jul 25 14:55:29.960: :cc_get_feature_vsa malloc success
004134: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004135: Jul 25 14:55:29.960:  cc_get_feature_vsa count is 5
004136: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004137: Jul 25 14:55:29.960: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308735632,feature_id:3883
004138: Jul 25 14:55:29.960: //2396/4FE2E67381E1/VTSP:(0/1/0):-1:1:2/vtsp_spi_event_handler:
004139: Jul 25 14:55:29.960: //2398/4FE2E67381E1/CCAPI/ccIFCallSetupRequestPrivate:
004140: Jul 25 14:55:29.960: //-1/4FE2E67381E1/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: Success in ccTDUtilSetDataInstance
004141: Jul 25 14:55:29.960: //2396/4FE2E67381E1/CCAPI/ccCallSetupRequest:
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
004142: Jul 25 14:55:29.960: //2398/4FE2E67381E1/CCAPI/ccCallSetContext:
   Context=0x899DD5D4
004143: Jul 25 14:55:29.960: //2396/4FE2E67381E1/CCAPI/ccSaveDialpeerTag:
004144: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004145: Jul 25 14:55:29.960:  feature call forward featname is 3
004146: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004147: Jul 25 14:55:29.960:  feature_vsa is 899C8288,featname is 0
004148: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004149: Jul 25 14:55:29.960: :cc_get_feature_vsa malloc success
004150: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004151: Jul 25 14:55:29.960:  cc_get_feature_vsa count is 6
004152: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004153: Jul 25 14:55:29.960: :FEATURE_VSA attributes are: feature_name:0,feature_time:2308733616,feature_id:3884
004154: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004155: Jul 25 14:55:29.960: : Generating new featurevsa,inserting it
004156: Jul 25 14:55:29.960: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004157: Jul 25 14:55:29.960:  feature call forward featname is 3
004158: Jul 25 14:55:29.960: //2398/xxxxxxxxxxxx/VTSP:(0/1/0):-1:-1:-1/vtsp_og_call_req:
004159: Jul 25 14:55:29.960: //2396/4FE2E67381E1/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=ALL_BRI, tg_label_flag=TRUE, Call Id=0x95C
004160: Jul 25 14:55:29.960: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_create: .
004161: Jul 25 14:55:29.960: //2398/51B70A649BE7/DSM:(0/1/0):-1/set_echo_canceller_data: echo_cancel: 1
004162: Jul 25 14:55:29.960: //2398/51B70A649BE7/DSM:(0/1/0):-1/set_echo_canceller_data: echo_flags: 55, echo_len: 1024
004163: Jul 25 14:55:29.964: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsmp_dsmapi_reserve_resource_cb: .
004164: Jul 25 14:55:29.964: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_set_elog_enable: .
004165: Jul 25 14:55:29.964: //2398/51B70A649BE7/VTSP:(0/1/0):-1:0:0/vtsp_create_call_active_on_setup_req:
004166: Jul 25 14:55:29.964: //2398/51B70A649BE7/VTSP:(0/1/0):-1:0:0/vtsp_create_call_active_on_setup_req:
004167: Jul 25 14:55:29.968: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x1, Calling num [Customer_Main_Number]
004168: Jul 25 14:55:29.968: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0042 callID = 0x8189 switch = basic-net3 interface = User
004169: Jul 25 14:55:29.968: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=2 nr=0
004170: Jul 25 14:55:29.968: ISDN BR0/1/0 Q931: SETUP pd = 8  callref = 0x42
Standard = CCITT
Channel ID i = 0x8A
Exclusive, B2
Calling Party Number i = 0x0181, '[Customer_Main_Number]'
Called Party Number i = 0xC1, '[Forwarding_Destination]'
Sending Complete
004171: Jul 25 14:55:30.004: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=3
004172: Jul 25 14:55:30.236: ISDN BR0/1/0 Q921: User RX <- INFO sapi=0 tei=75, ns=0 nr=3
004173: Jul 25 14:55:30.236: ISDN BR0/1/0 Q931: CALL_PROC pd = 8  callref = 0xC2
Channel ID i = 0x8A
Exclusive, B2
004174: Jul 25 14:55:30.236: ISDN BR0/1/0 Q921: User TX -> RR sapi=0 tei=75 nr=1
004175: Jul 25 14:55:30.236: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_reinit_platform_info: .
004176: Jul 25 14:55:30.236: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_set_dsp_allocated: .
004177: Jul 25 14:55:30.236: //2398/4FE2E67381E1/CCAPI/cc_api_call_proceeding:
   Interface=0x8869A614, Progress Indication=NULL(0)
004178: Jul 25 14:55:30.240: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsmp_dsmapi_reserve_resource_cb: .
004179: Jul 25 14:55:30.260: ISDN BR0/1/0 Q921: User RX <- INFO sapi=0 tei=75, ns=1 nr=3
004180: Jul 25 14:55:30.260: ISDN BR0/1/0 Q931: DISCONNECT pd = 8  callref = 0xC2
Cause i = 0x829C - Invalid number format (incomplete number)
Facility i = 0x91A109020200800201230500
Protocol Profile = Remote Operations Protocol
0xA109020200800201230500
Component = Invoke component, Unsupported operation
Progress Ind i = 0x8288 - In-band info or appropriate now available
004181: Jul 25 14:55:30.260: ISDN BR0/1/0 Q921: User TX -> RR sapi=0 tei=75 nr=2
004182: Jul 25 14:55:30.264: ISDN BR0/1/0 **ERROR**: isdnAsn1Inv: error: op 35
004183: Jul 25 14:55:30.264: ISDN BR0/1/0 **ERROR**: isdnAsn1Component: ERROR
004184: Jul 25 14:55:30.264: ISDN BR0/1/0 **ERROR**: process_facility_ie: Decode of facility IE operation 35 failed1
004185: Jul 25 14:55:30.264: ISDN BR0/1/0 **ERROR**: isdnAsn1Inv: error: op 35
004186: Jul 25 14:55:30.264: ISDN BR0/1/0 **ERROR**: isdnAsn1Component: ERROR
004187: Jul 25 14:55:30.264: ISDN BR0/1/0 **ERROR**: process_facility_ie: Decode of facility IE operation 35 failed1
004188: Jul 25 14:55:30.264: //2398/4FE2E67381E1/CCAPI/cc_api_call_facility:
   Interface=0x8869A614, Call Id=2398
004189: Jul 25 14:55:30.264: //2398/4FE2E67381E1/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=28, Progress Indication=INBAND(8), Interface=0x8869A614
004190: Jul 25 14:55:30.264: //2398/4FE2E67381E1/CCAPI/cc_api_call_disc_prog_ind:
   Event(Progress Indication=0x8), Call Entry(Responsed=TRUE)
004191: Jul 25 14:55:30.268: //2396/4FE2E67381E1/CCAPI/ccCallFacility:
   Call Id=2396
004192: Jul 25 14:55:30.268: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=3 nr=2
004193: Jul 25 14:55:30.268: ISDN BR0/1/0 Q931: FACILITY pd = 8  callref = 0xE2
Facility i = 0x9E810003677464000000164641432C0D0A50524E2C6973646E2A2C2C2C0D0A0D0A
- Unknown Service Discriminator 158
004194: Jul 25 14:55:30.268: //2396/4FE2E67381E1/CCAPI/ccCallDiscProgInd:
004195: Jul 25 14:55:30.268: //2396/4FE2E67381E1/CCAPI/ccCallDiscProgInd:
   Call Entry(Responsed=TRUE, Disconnect Cause=28)
004196: Jul 25 14:55:30.268: //2396/4FE2E67381E1/CCAPI/ccConferenceCreate:
   (confID=0x890120A8, callID1=0x95C, gcid=4FE2E673-F46011E2-81E1ACF2-C59E4440, tag=0x0)
004197: Jul 25 14:55:30.268: //2398/4FE2E67381E1/CCAPI/ccConferenceCreate:
   (confID=0x890120A8, callID2=0x95E, gcid=4FE2E673-F46011E2-81E1ACF2-C59E4440, tag=0x0)
004198: Jul 25 14:55:30.268: //2396/4FE2E67381E1/CCAPI/ccConferenceCreate:
   Conference Id=0x890120A8, Call Id1=2396, Call Id2=2398, Tag=0x0
004199: Jul 25 14:55:30.272: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_bridge: .
004200: Jul 25 14:55:30.272: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_bridge:
004201: Jul 25 14:55:30.272:  dsp_stream_mgr_bridge, src_call_id 2396, dst_call_id 2398
004202: Jul 25 14:55:30.272: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_bridge: creating packet streams
004203: Jul 25 14:55:30.272: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_insert_conn_array_entry: dmgr->connArr.count = 2
004204: Jul 25 14:55:30.272: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_bridge: doing DSP less hairpin
004205: Jul 25 14:55:30.272: //2396/4FE2E67381E1/CCAPI/cc_api_bridge_done:
   Conference Id=0x2CE, Source Interface=0x8869A614, Source Call Id=2396,
   Destination Call Id=2398, Disposition=0x0, Tag=0xFFFFFFFF
004206: Jul 25 14:55:30.272: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_set_feature_parameters: Fax Relay Mode = 4, Primary Fax Protocol = 1
Fax fallback protocol = 4, T.38 Fax Version 0
004207: Jul 25 14:55:30.272: //2396/4FE2E67381E1/VTSP:(0/1/0):-1:1:2/vtsp_dsm_save_tty_config:
   Save TTY configuration
004208: Jul 25 14:55:30.272: //2396/4FE2E67381E1/VTSP:(0/1/0):-1:1:2/vtsp_dsm_set_tty_feat_param:
   Set TTY feat parameters
004209: Jul 25 14:55:30.272: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_bridge: .
004210: Jul 25 14:55:30.272: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_bridge:
004211: Jul 25 14:55:30.272:  dsp_stream_mgr_bridge, src_call_id 2398, dst_call_id 2396
004212: Jul 25 14:55:30.272: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_bridge: creating packet streams
004213: Jul 25 14:55:30.272: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_insert_conn_array_entry: dmgr->connArr.count = 2
004214: Jul 25 14:55:30.272: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_bridge: doing DSP less hairpin
004215: Jul 25 14:55:30.272: //2398/4FE2E67381E1/CCAPI/cc_api_bridge_done:
   Conference Id=0x2CE, Source Interface=0x8869A614, Source Call Id=2398,
   Destination Call Id=2396, Disposition=0x0, Tag=0xFFFFFFFF
004216: Jul 25 14:55:30.272: //2396/4FE2E67381E1/CCAPI/cc_generic_bridge_done:
004217: Jul 25 14:55:30.272: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_set_feature_parameters: Fax Relay Mode = 4, Primary Fax Protocol = 1
004218: Jul 25 14:55:30.272: //2398/51B70A649BE7/VTSP:(0/1/0):-1:1:3/vtsp_dsm_save_tty_config:
004219: Jul 25 14:55:30.276: //2398/51B70A649BE7/VTSP:(0/1/0):-1:1:3/vtsp_dsm_set_tty_feat_param:
004220: Jul 25 14:55:30.276: //2396/4FE2E67381E1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2CE, Destination Call Id=2398)
004221: Jul 25 14:55:30.276: //2398/4FE2E67381E1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2CE, Destination Call Id=2396)
004222: Jul 25 14:55:30.276: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_do_caps_ind: .
004223: Jul 25 14:55:30.276: //2396/4FE2E67381E1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x8869A614, Destination Call Id=2398, Source Call Id=2396,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
004224: Jul 25 14:55:30.276: //2396/4FE2E67381E1/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
004225: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
004226: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
004227: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
004228: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
004229: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=83
004230: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=[Forwarding_Destination], Peer Info Type=DIALPEER_INFO_SPEECH
004231: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=[Forwarding_Destination]
004232: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
004233: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
004234: Jul 25 14:55:30.276: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
004235: Jul 25 14:55:30.276: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_do_caps_ind: .
004236: Jul 25 14:55:30.276: //2398/4FE2E67381E1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x8869A614, Destination Call Id=2396, Source Call Id=2398,
004237: Jul 25 14:55:30.276: //2398/4FE2E67381E1/CCAPI/cc_api_caps_ind:
004238: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: src_call_id = 2398, dst_call_id = 2396, is_cap_ack = 0
004239: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps in caps indication:
004240: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004241: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004242: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004243: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
             FaxRate 2, FaxBytes 20, FaxNsf 0xAD0051
             T.38 Fax Version 0, SignalType 2
             DtmfRelay 1, Modem 2, SeqNumStart 0xF90
004244: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps after caps negotiation:
004245: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004246: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004247: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004248: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
004249: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: packet streams already created during bridging
004250: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps in caps indication:
004251: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004252: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004253: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004254: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
004255: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps negotiation: ephone-ephone
004256: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps after caps negotiation:
004257: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004258: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004259: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004260: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
004261: Jul 25 14:55:30.280: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: Fax CM and ANS suppression is enabled, cm suppress 1 ans suppress 0
004262: Jul 25 14:55:30.280: //2398/4FE2E67381E1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3984)
004263: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: src_call_id = 2396, dst_call_id = 2398, is_cap_ack = 1
004264: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: src_call_id = 2396, dst_call_id = 2398, is_cap_ack = 0
004265: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps in caps indication:
004266: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004267: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004268: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004269: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
             DtmfRelay 1, Modem 2, SeqNumStart 0xEC2
004270: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps after caps negotiation:
004271: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004272: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004273: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004274: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
004275: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: packet streams already created during bridging
004276: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps in caps indication:
004277: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004278: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004279: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004280: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
004281: Jul 25 14:55:30.280: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps negotiation: ephone-ephone
004282: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_ind_negotiation: Caps after caps negotiation:
004283: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: playout: [ mode:1,init:60, min:40, max:1000]. data_mode:0
004284: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: RTP PT:NTE[0],NSE[100],FaxInd[96],FaxAck[97],CiscoDTMF[121],FaxRelay[122],CASsig[123],TTY[119],ClearChan[125],PCMu[0],PCMa[8]LmrTonePayload[0], NteTonePayload[0],Codec[1], TxDynamicPayload[0], RxDynamicPayload[0]
004285: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_caps_dump: passthrough: cap_modem_proto 0,cap_modem_codec 0, cap_modem_redundancy 0, payload 0, modem_relay 0, gw-xid 1, sprt_retries 12, sse pt 118, sprt pt 120, t1 1000, retries 3, v14_rx_ht 50, v14_tx_ht 20, v14_tx_hc 16, ec 1, phy 1
004286: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_debug_caps_encap: Encap 1, Vad 2, Codec 0x1, CodecBytes 160,
004287: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: Fax CM and ANS suppression is enabled, cm suppress 1 ans suppress 0
004288: Jul 25 14:55:30.284: //2396/4FE2E67381E1/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3778)
004289: Jul 25 14:55:30.284: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_cap_ind_ack: src_call_id = 2398, dst_call_id = 2396, is_cap_ack = 1
004290: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_stop_service:
    G711_U (5)
004291: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_close_service:
    G711_U (5)
004292: Jul 25 14:55:30.284: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_close_service:
    NONE (0)
004293: Jul 25 14:55:30.284: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_init:
004294: Jul 25 14:55:30.284: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_open_service:
    G711_U (5)
004295: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_init:
004296: Jul 25 14:55:30.284: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_open_service:
    G711_U (5)
004297: Jul 25 14:55:30.284: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_voice_config_params:
004298: Jul 25 14:55:30.284:     7 parameters
    [0] ENCAP RTP: Tx SSRC=768, Rx SSRC=0, Tx VPXCC=128, Rx VPXCC=0
    IFP payload type=122, SID support=19, TSE payload=101, Sequence number start=3984
    Redundancy=0, ClearChannel payload type=125, Fax payload type=122
    Alaw PCM switchover=8, MuLAW PCM switchover=0
    DTMF payload type=121, NTE receive payload type=0
    Dynamic payload=0, Codec=g711ulaw
    [3] MR_PROTOCOL: 0 bytes
    [4] IDLE_CODE_DET: Enable=0, Code=0x0, Duration=6000(ms)
    [5] ECHO_CANCEL: Flags=0x37, Echo length=128(ms)
    [6] CNG: 1
004299: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_config_params:
    3 parameters
004300: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_start_service:
    G711_U (5)
004301: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_call_progress_detect:
004302: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_voice_config_params:
004303: Jul 25 14:55:30.288:     5 parameters
    [3] DIGIT_RELAY: 2
    [4] VAD: Enable=1, Threshold=-38(dBm)
004304: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsmp_dsmapi_connect_cb: .
004305: Jul 25 14:55:30.288: //2398/4FE2E67381E1/CCAPI/cc_api_voice_mode_event:
   Call Id=2398
004306: Jul 25 14:55:30.288: //2398/4FE2E67381E1/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x899DD5D4)
004307: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsmp_dsmapi_connect_cb: dmgr->current_feature = 1, dmgr->previous_feature = 0
004308: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_call_progress_detect:
004309: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_inband_det_ctrl:
    SignalType=1, Mode=1, Signal suppression bitmap 0, signal suppression mode 0
004310: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_inband_det_ctrl:
    SignalType=4, Mode=1, Signal suppression bitmap 0, signal suppression mode 0
004311: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_inband_det_ctrl:
    SignalType=5, Mode=1, Signal suppression bitmap 0, signal suppression mode 0
004312: Jul 25 14:55:30.288: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_inband_det_ctrl:
    SignalType=9, Mode=1, Signal suppression bitmap 1, signal suppression mode 1
004313: Jul 25 14:55:30.288: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_voice_config_params:
004314: Jul 25 14:55:30.288:     7 parameters
    [0] ENCAP RTP: Tx SSRC=770, Rx SSRC=0, Tx VPXCC=128, Rx VPXCC=0
    IFP payload type=122, SID support=19, TSE payload=101, Sequence number start=3778
    [6] CNG: 1
004315: Jul 25 14:55:30.288: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_config_params:
    3 parameters
004316: Jul 25 14:55:30.288: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_start_service:
    G711_U (5)
004317: Jul 25 14:55:30.288: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_call_progress_detect:
004318: Jul 25 14:55:30.288: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_voice_config_params:
004319: Jul 25 14:55:30.288:     5 parameters
    [3] DIGIT_RELAY: 2
004320: Jul 25 14:55:30.288: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsmp_dsmapi_connect_cb: .
004321: Jul 25 14:55:30.288: //2396/4FE2E67381E1/CCAPI/cc_api_voice_mode_event:
   Call Id=2396
004322: Jul 25 14:55:30.288: //2396/4FE2E67381E1/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x899DFF54)
004323: Jul 25 14:55:30.288: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsmp_dsmapi_connect_cb: dmgr->current_feature = 1, dmgr->previous_feature = 0
004324: Jul 25 14:55:30.292: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_voice_config_params:
004325: Jul 25 14:55:30.292:     1 parameter
    [0] PAK_SUPPRESS: 0
004326: Jul 25 14:55:30.292: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_call_progress_detect:
004327: Jul 25 14:55:30.292: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_det_ctrl:
004328: Jul 25 14:55:30.292: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_det_ctrl:
004329: Jul 25 14:55:30.292: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_det_ctrl:
004330: Jul 25 14:55:30.292: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_inband_det_ctrl:
004331: Jul 25 14:55:30.292: //2396/4FE2E67381E1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2CE, Call Id1=2396, Call Id2=2398
004332: Jul 25 14:55:30.308: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=4
004333: Jul 25 14:55:30.308: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=4 nr=2
004334: Jul 25 14:55:30.308: ISDN BR0/1/0 Q931: DISCONNECT pd = 8  callref = 0xE2
Cause i = 0x809C - Invalid number format (incomplete number)
004335: Jul 25 14:55:30.336: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=5
004336: Jul 25 14:55:30.364: ISDN BR0/1/0 Q921: User RX <- INFO sapi=0 tei=75, ns=2 nr=5
004337: Jul 25 14:55:30.364: ISDN BR0/1/0 Q931: FACILITY pd = 8  callref = 0x62
Facility i = 0x91A40702020080810101
0xA40702020080810101
Component = Reject component
Invoke Id = 128
Problem = Invoke problem; Unrecognized operation
004338: Jul 25 14:55:30.364: ISDN BR0/1/0 Q921: User TX -> RR sapi=0 tei=75 nr=3
004339: Jul 25 14:55:30.364: ISDN BR0/1/0 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x1FD, call ref 0xE2, event 0x62
004340: Jul 25 14:55:30.364: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=5 nr=3
004341: Jul 25 14:55:30.364: ISDN BR0/1/0 Q931: STATUS pd = 8  callref = 0xE2
Cause i = 0x80E262 - Message not compatible with call state or not implemented
Call State i = 0x0B
004342: Jul 25 14:55:30.388: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=6
004343: Jul 25 14:55:30.404: ISDN BR0/1/0 Q921: User RX <- INFO sapi=0 tei=75, ns=3 nr=6
004344: Jul 25 14:55:30.404: ISDN BR0/1/0 Q931: RELEASE pd = 8  callref = 0x62
Cause i = 0x82E31E - Information element not implemented
004345: Jul 25 14:55:30.404: ISDN BR0/1/0 Q921: User TX -> RR sapi=0 tei=75 nr=4
004346: Jul 25 14:55:30.408: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=6 nr=4
004347: Jul 25 14:55:30.408: ISDN BR0/1/0 Q931: RELEASE_COMP pd = 8  callref = 0xE2
004348: Jul 25 14:55:30.408: //2396/4FE2E67381E1/VTSP:(0/1/0):-1:1:2/vtsp_cc_call_disconnected:
   Cause Value=99
004349: Jul 25 14:55:30.408: //2396/4FE2E67381E1/CCAPI/cc_api_call_disconnected:
   Cause Value=99, Interface=0x8869A614, Call Id=2396
004350: Jul 25 14:55:30.408: //2396/4FE2E67381E1/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=28, Retry Count=0)
004351: Jul 25 14:55:30.408: //2396/4FE2E67381E1/CCAPI/ccConferenceDestroy:
   Conference Id=0x2CE, Tag=0x0
004352: Jul 25 14:55:30.412: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_bridge_drop:
004353: Jul 25 14:55:30.412:  dsp_stream_mgr_bridge_drop, src_call_id 2396, dst_call_id 2398
004354: Jul 25 14:55:30.412: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_delete_conn_array_entry: dmgr->connArr.count = 0
004355: Jul 25 14:55:30.412: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_disconnect_and_delete_video_streams: .
004356: Jul 25 14:55:30.412: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_disconnect_and_delete_video_streams: stm_id: 0, call_id: 0
004357: Jul 25 14:55:30.412: //2396/4FE2E67381E1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2398, Disposition=0x0, Tag=0x0
004358: Jul 25 14:55:30.412: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_bridge_drop:
004359: Jul 25 14:55:30.412:  dsp_stream_mgr_bridge_drop, src_call_id 2398, dst_call_id 2396
004360: Jul 25 14:55:30.412: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_delete_conn_array_entry: dmgr->connArr.count = 0
004361: Jul 25 14:55:30.412: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_disconnect_and_delete_video_streams: .
004362: Jul 25 14:55:30.412: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_disconnect_and_delete_video_streams: stm_id: 0, call_id: 0
004363: Jul 25 14:55:30.412: //2398/4FE2E67381E1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2396, Disposition=0x0, Tag=0x0
004364: Jul 25 14:55:30.412: //2396/4FE2E67381E1/CCAPI/cc_generic_bridge_done:
004365: Jul 25 14:55:30.412: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_voice_config_params:
004366: Jul 25 14:55:30.412:     1 parameter
    [0] PAK_SUPPRESS: 1
004367: Jul 25 14:55:30.412: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_voice_config_params:
004368: Jul 25 14:55:30.412:     1 parameter
    [0] PAK_SUPPRESS: 1
004369: Jul 25 14:55:30.416: //2398/4FE2E67381E1/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=28)
004370: Jul 25 14:55:30.416: //2398/4FE2E67381E1/CCAPI/ccCallDisconnect:
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
004371: Jul 25 14:55:30.416: //2398/4FE2E67381E1/CCAPI/cc_api_get_transfer_info:
004372: Jul 25 14:55:30.416: //2396/4FE2E67381E1/CCAPI/ccCallDisconnect:
004373: Jul 25 14:55:30.416: //2396/4FE2E67381E1/CCAPI/ccCallDisconnect:
004374: Jul 25 14:55:30.416: //2396/4FE2E67381E1/CCAPI/cc_api_get_transfer_info:
004375: Jul 25 14:55:30.416: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_set_feature_parameters: Fax Relay Mode = 4, Primary Fax Protocol = 1
004376: Jul 25 14:55:30.416: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_initiate_close: .
004377: Jul 25 14:55:30.420: //2398/4FE2E67381E1/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=28
004378: Jul 25 14:55:30.420: //2398/4FE2E67381E1/CCAPI/cc_api_call_disc_cause_update:
   Call Entry(Disconnect Cause=28)
004379: Jul 25 14:55:30.420: //2398/51B70A649BE7/VTSP:(0/1/0):-1:1:3/vtsp_do_call_history:
   Coder Rate=5
004380: Jul 25 14:55:30.420: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsp_stream_mgr_destroy: .
004381: Jul 25 14:55:30.420: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsm_delete_all_streams: .
004382: Jul 25 14:55:30.420: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsmapi_accept_modem_passthrough_session:  : dmgr: 86698CE0, active sessions 0, max sessions: 16 rejected sessions till now: 0
004383: Jul 25 14:55:30.420: //2396/4FE2E67381E1/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=28
004384: Jul 25 14:55:30.420: //2396/4FE2E67381E1/CCAPI/cc_api_call_disc_cause_update:
004385: Jul 25 14:55:30.420: //2396/4FE2E67381E1/VTSP:(0/1/0):-1:1:2/vtsp_do_call_history:
   Coder Rate=5
004386: Jul 25 14:55:30.420: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsp_stream_mgr_destroy: .
004387: Jul 25 14:55:30.420: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsm_delete_all_streams: .
004388: Jul 25 14:55:30.424: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsmapi_accept_modem_passthrough_session:  : dmgr: 8AD9F7CC, active sessions 0, max sessions: 16 rejected sessions till now: 0
004389: Jul 25 14:55:30.424: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_stop_service:
    G711_U (5)
004390: Jul 25 14:55:30.424: //2398/51B70A649BE7/DSPAPI/[0/1:3]/dsp_close_service:
    G711_U (5)
004391: Jul 25 14:55:30.424: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_stop_service:
    G711_U (5)
004392: Jul 25 14:55:30.424: //2396/4FE2E67381E1/DSPAPI/[0/1:2]/dsp_close_service:
    G711_U (5)
004393: Jul 25 14:55:30.424: //2398/51B70A649BE7/DSM:(0/1/0):-1/dsmp_dsmapi_reserve_resource_cb: .
004394: Jul 25 14:55:30.424: //2396/4FE2E67381E1/DSM:(0/1/0):-1/dsmp_dsmapi_reserve_resource_cb: .
004395: Jul 25 14:55:30.424: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=7
004396: Jul 25 14:55:30.424: //2398/4FE2E67381E1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8869A614, Tag=0x0, Call Id=2398,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
004397: Jul 25 14:55:30.424: //-1/4FE2E67381E1/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x89AE5E5C; count=1
004398: Jul 25 14:55:30.428: //-1/4FE2E67381E1/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x89410D90
004399: Jul 25 14:55:30.428: //2398/4FE2E67381E1/CCAPI/cc_api_call_disconnect_done:
   tg for this call is ALL_BRI success/fail is 0
004400: Jul 25 14:55:30.428: //2398/4FE2E67381E1/CCAPI/cc_api_call_disconnect_done:
004401: Jul 25 14:55:30.428: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004402: Jul 25 14:55:30.428: :cc_free_feature_vsa freeing 899C7AA8
004403: Jul 25 14:55:30.428: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004404: Jul 25 14:55:30.428:  vsacount in free is 5
004405: Jul 25 14:55:30.428: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004406: Jul 25 14:55:30.428:  vsacount in free is 4
004407: Jul 25 14:55:30.428: //2396/4FE2E67381E1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x8869A614, Tag=0x0, Call Id=2396,
004408: Jul 25 14:55:30.428: //-1/4FE2E67381E1/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x89AE443C; count=2
004409: Jul 25 14:55:30.428: //-1/4FE2E67381E1/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x89412950
004410: Jul 25 14:55:30.428: //2396/4FE2E67381E1/CCAPI/cc_api_call_disconnect_done:
004411: Jul 25 14:55:30.428: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004412: Jul 25 14:55:30.428: :cc_free_feature_vsa freeing 899C7FE8
004413: Jul 25 14:55:30.428: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004414: Jul 25 14:55:30.428:  vsacount in free is 3
004415: Jul 25 14:55:30.428: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004416: Jul 25 14:55:30.428:  vsacount in free is 2
004417: Jul 25 14:55:30.432: ISDN BR0/1/0 Q921: User TX -> INFO sapi=0 tei=75, ns=7 nr=4
004418: Jul 25 14:55:30.432: ISDN BR0/1/0 Q931: RELEASE pd = 8  callref = 0x42
004419: Jul 25 14:55:30.448: ISDN BR0/1/0 Q921: User RX <- RR sapi=0 tei=75 nr=8
004420: Jul 25 14:55:30.488: ISDN BR0/1/0 Q921: User RX <- INFO sapi=0 tei=75, ns=4 nr=8
004421: Jul 25 14:55:30.488: ISDN BR0/1/0 Q931: RELEASE_COMP pd = 8  callref = 0xC2
004422: Jul 25 14:55:30.488: ISDN BR0/1/0 Q921: User TX -> RR sapi=0 tei=75 nr=5
004423: Jul 25 14:55:39.664: //1/D57121248002/DSM:(50/0/9):-1/dsp_stream_mgr_get_levels_sync: .
004424: Jul 25 14:55:39.664: //1/D57121248002/DSPAPI/[]/dsp_query_info:
    Request ID=6, Reset Flag=FALSE Q:TX RX Levels
004425: Jul 25 14:55:39.664: //1/D57121248002/DSPAPI/[]/dsp_tx_stats:
    Request ID=6, Packets: Voice=0, Signaling=0, ComfortNoise=0
    TX duration=0(ms): Voice=0(ms), FAX=0(ms)
004426: Jul 25 14:55:39.664: //1/D57121248002/DSPAPI/[]/dsp_rx_stats:
    Request ID=6, Packets: Voice=0, Signalling=0, ComfortNoise=0
    RX duration=0(ms): Voice=0(ms), FAX=0(ms)
    Packets: Bad Sequence=0, Bad Protocol=0, Late=0, Early=0
004427: Jul 25 14:55:39.664: //1/D57121248002/DSPAPI/[]/dsp_level_stats:
    Request ID=6, TX: power=0.0(dBm0), mean=0.0(linear PCM), RX: power=0.0(dBm0), mean=0.0(linear PCM)
    Background Noise=0.0(dBm0), ERL level=0.0(dB)
    ACOM level=0.0(dB), Current TX act=2, Current RX act=2
    Reflector locations: 0(ms) 32768(ms) 45977(ms), MAX reflector=37830(ms)
    2 ECAN control words: 554B 0, ECAN Version=1F3A.FFFF(na)
004428: Jul 25 14:55:39.664: //1/D57121248002/DSM:(50/0/9):-1/dsmp_dsmapi_stats_cb: .
004429: Jul 25 14:55:39.664: //2/D57121248002/DSM:(0/4/0):-1/dsp_stream_mgr_get_levels_sync: .
004430: Jul 25 14:55:39.664: //2/D57121248002/DSPAPI/[0/1:1]/dsp_query_info:
004431: Jul 25 14:55:39.672: //2/D57121248002/DSPAPI/[0/1:1]/dsp_tx_stats:
    Request ID=6, Packets: Voice=121541417, Signaling=0, ComfortNoise=0
    TX duration=-1864138946(ms): Voice=-1864138946(ms), FAX=0(ms)
004432: Jul 25 14:55:39.672: //2/D57121248002/DSPAPI/[0/1:1]/dsp_rx_stats:
    RX duration=-1864138946(ms): Voice=0(ms), FAX=0(ms)
004433: Jul 25 14:55:39.672: //2/D57121248002/DSPAPI/[0/1:1]/dsp_level_stats:
    Request ID=6, TX: power=-64.0(dBm0), mean=-79.3(linear PCM), RX: power=-68.5(dBm0), mean=-55.3(linear PCM)
    Background Noise=-81.0(dBm0), ERL level=6.0(dB)
    ACOM level=6.0(dB), Current TX act=1, Current RX act=1
    Reflector locations: 4(ms) 0(ms) 0(ms), MAX reflector=4(ms)
    2 ECAN control words: 7C 1000, ECAN Version=9183.890
004434: Jul 25 14:55:39.672: //2/D57121248002/DSM:(0/4/0):-1/dsmp_dsmapi_stats_cb: .
004435: Jul 25 14:55:40.488: ISDN BR0/1/0 Q921: User TX -> RRp sapi=0 tei=75 nr=5
004436: Jul 25 14:55:40.500: ISDN BR0/1/0 Q921: User RX <- RRf sapi=0 tei=75 nr=8
004437: Jul 25 14:55:45.436: ISDN BR0/1/0 Q921: User RX <- DISCp sapi=0 tei=75
004438: Jul 25 14:55:45.440: ISDN BR0/1/0 Q921: User TX -> UAf sapi=0 tei=75
004439: Jul 25 14:55:45.440: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
-----------------------------------------------------------------------------END-----------------------------------------------------------------------------
Is it possible, that the incoming number can't be replaced with the customer number by forwarding the call and the pstn is blocking the call?
please help.
best regards
claude
Only post the debug mentioned and nothing more.
Hallo Paolo
Thanks for your answer. Is that OK?
Best Regards
Claude
*******NORMAL INCOMING CALL*******
005592: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x69
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0181, '0417256565'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xC1, '8504452'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
005593: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xE9
        Channel ID i = 0x89
                Exclusive, B1
005594: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8  callref = 0xE9
005595: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8  callref = 0xE9
        Channel ID i = 0x89
                Exclusive, B1
005596: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x69
005597: Jul 30 07:43:10.107: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 21 Hauptapparat Alpina
005598: Jul 30 07:43:29.955: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from 0417256565 , call lasted 19 seconds
005599: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0xE9
        Cause i = 0x8090 - Normal call clearing
005600: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x69
005601: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xE9
005602: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
005603: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 8502086
005604: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 0417256565
005605: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0073 callID = 0x81BA switch = basic-net3 interface = User
*******NORMAL OUTGOING CALL*******
005606: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x73
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0080, '8502086'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0417256565'
        Sending Complete
005607: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xF3
        Channel ID i = 0x89
                Exclusive, B1
005608: ISDN BR0/1/0 Q931: RX <- CONNECT pd = 8  callref = 0xF3
        Date/Time i = 0x0D071E0930
                Date (dd-mm-yr)   = 13-07-30
                Time (hr:mnt:sec) = 09:48:76
        Connected Number i = 0x0183, '0417256565'
005609: Jul 30 07:44:36.123: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 21 Hauptapparat Alpina
005610: ISDN BR0/1/0 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x73
005611: ISDN BR0/1/0 Q931: RX <- FACILITY pd = 8  callref = 0xF3
        Facility i = 0x91A11B020200800201213012A10D810346522EA20681010A820101820100
                0xA11B020200800201213012A10D810346522EA20681010A820101820100
                        Invoke Id = 128
                        Operation = AOCDCurrency
                                Currency = FR.
                                Currency amount = 10, Multiplier = 1/100
                                Type of charging : Subtotal
005612: ISDN BR0/1/0 Q931: RX <- INFORMATION pd = 8  callref = 0xF3
        Display i = 'FR. 0.10'
005613: Jul 30 07:44:44.711: %SYS-5-CONFIG_I: Configured from http by sysadminacc on 192.168.30.2
005614: Jul 30 07:44:53.775: %SYS-5-CONFIG_I: Configured from http by sysadminacc on 192.168.30.2
005615: Jul 30 07:45:06.039: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from 0417256565 , call lasted 29 seconds
005616: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x73
005617: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0xF3
        Facility i = 0x91A11A020200810201233011300FA10D810346522EA20681010A820101
                0xA11A020200810201233011300FA10D810346522EA20681010A820101
                        Invoke Id = 129
                        Operation = AOCECurrency
                                Currency = FR.
                                AOC-E Charging association Charge Identifier 0
005618: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x73
005619: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*******CHANGE CONFIGURATION ON UC540 TO REDIRECT CALLS TO EXTERNAL MOBILE PHONE*******
005620: Jul 30 07:46:00.235: %SYS-5-CONFIG_I: Configured from console by sysadminacc on vty1 (192.168.30.2)
005621: Jul 30 07:47:08.419: %SYS-5-CONFIG_I: Configured from console by sysadminacc on vty1 (192.168.30.2)
005622: Jul 30 07:47:11.999: %SYS-5-CONFIG_I: Configured from http by sysadminacc on 192.168.30.2
*******INCOMING CALL THAT SHOULD BE REDIRECTED TO MOBILE PHONE --> FAILED*******
005623: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x68
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
005624: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xE8
        Channel ID i = 0x89
                Exclusive, B1
005625: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8  callref = 0xE8
        Progress Ind i = 0x8188 - In-band info or appropriate now available
005626: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x1, Calling num 8502086
005627: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0074 callID = 0x81BB switch = basic-net3 interface = User
005628: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x74
                Standard = CCITT
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x0181, '8502086'
        Called Party Number i = 0xC1, '0785554044'
        Sending Complete
005629: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xF4
        Channel ID i = 0x8A
                Exclusive, B2
005630: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0xF4
005631: ISDN BR0/1/0 **ERROR**: isdnAsn1Inv: error: op 35
005632: ISDN BR0/1/0 **ERROR**: isdnAsn1Component: ERROR
005633: ISDN BR0/1/0 **ERROR**: process_facility_ie: Decode of facility IE operation 35 failed1
005634: ISDN BR0/1/0 **ERROR**: isdnAsn1Inv: error: op 35
005635: ISDN BR0/1/0 **ERROR**: isdnAsn1Component: ERROR
005636: ISDN BR0/1/0 **ERROR**: process_facility_ie: Decode of facility IE operation 35 failed1
005637: ISDN BR0/1/0 Q931: TX -> FACILITY pd = 8  callref = 0xE8
005638: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0xE8
005639: ISDN BR0/1/0 Q931: RX <- FACILITY pd = 8  callref = 0x68
                        Invoke Id = 128
005640: ISDN BR0/1/0 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x247, call ref 0xE8, event 0x62
005641: ISDN BR0/1/0 Q931: TX -> STATUS pd = 8  callref = 0xE8
        Call State i = 0x0B
005642: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0x68
005643: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xE8
005644: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x74
005645: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xF4
005646: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
*******END*******
try
interface bri01/0
isdn map address .  plan unknown type unknown
